Re: Iron or Aluminum?
[Re: BIG BEAR]
#294944
04/21/09 01:19 PM
04/21/09 01:19 PM
Posts: 13,543 Marion, South Carolina [><]
an8sec70cuda
The wedge will be in higher demand since there are a lot less people running hemis. Although, it'd be nice to have another hemi block on the market. The iron block would probably sell better due to the lower cost. Even though the aluminum block is better down the road as far as fixing a window or resleeving, most people just base their decision on initial cost. I went w/ an aluminum KB block b/c it's likely the last block I'll have to buy. If it gets worn out, I can resleeve it. If it blows up, I can have it repaired. Not to mention the machine work was quality and I did not need to massage much at all to use it right out the box. I bought mine before the World blocks were available. I heard so many horror stories about the old MP mega blocks machining that wound up costing as much as a KB block to make them useable. CHIP
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: BIG BEAR]
#294948
04/21/09 02:10 PM
04/21/09 02:10 PM
Posts: 4,281 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
There may be a market yet for a cheap, iron, unskirted(less iron and lighter), dowled 2-bolt main (9/16" stud), low-deck big-block, 4.56" bore (cast them larger), even with a GM bellhousing. Simplify the casting e.g. no fuel pump boss, or internal oil pick-up, etc... Put the feelers out in a thread like this. Or read thru the 440Source proposed block thread archieved in here. If the cost were low enough I'd guess you'll win-over the alloy block people 'cause it ain't cheap to properly repair/resleeve an aluminium block.
Post deleted by Defbob
[Re: BIG BEAR]
#294949
04/21/09 02:14 PM
04/21/09 02:14 PM
[Re: HardcoreB]
#294951
04/21/09 02:17 PM
04/21/09 02:17 PM
Posts: 627 IN
BIG BEAR
IN
why not just use a chevy block, fill in the head bold holes and drill and tap new ones, and use a mopar head? Or just get an Arias
[Re: BIG BEAR]
#294953
04/21/09 02:24 PM
04/21/09 02:24 PM
HardcoreB
Shelby Twp. Mi
deckheight, bore spacing, rocker oiling, lifter positioning. etc...I don't understand. Are you speaking as a MOPAR purist? Does your racecar have to have an 8 3/4 and a 727?
[Re: HardcoreB]
#294955
04/21/09 02:30 PM
04/21/09 02:30 PM
[Re: HardcoreB]
#294956
04/21/09 02:31 PM
04/21/09 02:31 PM
HardcoreB
Shelby Twp. Mi
cheap, iron, unskirted(less iron and lighter), dowled 2-bolt main (9/16" stud), low-deck big-block, 4.56" bore (cast them larger), even with a GM bellhousing. Simplify the casting e.g. no fuel pump boss, or internal oil pick-up, etc... cheap
Limited market for larger B/S unique combinations...However, there are plentiful supplies of top-ends that can push 800-1000HP especially with a power adder. Something these features should tolerate.
[Re: BIG BEAR]
#294959
04/21/09 02:41 PM
04/21/09 02:41 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Im speaking as a manufacturer, I'll make what will sell, but I dont think that there is enough money to justify the cause, or could I be wrong?
Just make an aluminum big block dodge for 1500 bucks and I guarantee you'll be laughing all the way to the bank $$ $$ $$
[Re: BIG BEAR]
#294960
04/21/09 02:42 PM
04/21/09 02:42 PM
HardcoreB
Shelby Twp. Mi
what do you think about a 4.84 bs block, would people be after it?
IMO you already market a HIGH-END block with good quality. How is that one selling for you? Even the B1/PSO and Predator heads are currently built around a 4.8" B/S. A larger B/S block is still a smaller market IMO and this is not the time (economically speaking) to build it assuming others will manufacter/engineer parts compatible. It's been nice chatting but, I gotta go...
[Re: an8sec70cuda]
#294962
04/21/09 02:43 PM
04/21/09 02:43 PM
