2004 Dakota transmission help #2927903
05/28/21 10:30 PM
05/28/21 10:30 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline OP
JDMopar  Offline OP
2004 Dakota, 4.7, 2WD, 545RFE automatic. Transmission came out of a 2007 Chrysler Aspen that got totaled with 37K miles on it. I have put 16K miles on it with no problems until yesterday. It has mainly been used around town as a daily driver, never towed anything, and we have never rawhided it. I was 5 miles from the end of a 300 mile road trip to the beach, and the truck just kind of hiccupped and the check engine light came on. Cruise was set at 70 mph, and truck went right on like nothing happened. Got to the end of the off ramp, and when I went to pull out.....the trans hadn't shifted back down. I pulled it down in low, and shifted it manually, and it seemed fine. I drove it to Autozone today, and got the dude to run the scan tool on it. No codes stored, and it had seemed fine on the 10 mile trip up the interstate, to get to Autozone. When i left there, it did it again, but this time, it also did not shift into OD when I got back on the interstate. Luckily, my wife has her car here at the beach too. Now I gotta take her car back home, hook the car trailer to my diesel, load her car and go back to the beach. Then load the Dakota up to bring it home when I go home from the beach on the 10th. Lot of work and driving, but cheaper than getting it towed!
Anybody have trouble with a 545RFE like this before? I called my trusted transmission guy at home, and he said it might be solenoid packs in the transmission. Fluid is full and clean, and there are no leaks. He also said he has seen some Dodge trucks have connector problems under the bottom of the underhood fuse box. Any help or ideas appreciated.
Re: 2004 Dakota transmission help [Re: JDMopar] #2927959
05/29/21 07:17 AM
05/29/21 07:17 AM
Guitar Jones Offline
I don't know how the aftermarket code readers work, but on the factory scan tools you may not get trans codes in the engine codes. It is a separate system. If the MIL is on there is a code, you just need to find the correct system to read it.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 2004 Dakota transmission help [Re: Guitar Jones] #2928106
05/29/21 01:41 PM
05/29/21 01:41 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Most autozone type scanners are only gonna pull engine codes, if your luck there is a P700 that tells you there is a tranny code but not what the code actually is.
Those trannies are very reliable, one of the most common problems I have seen is the filter in the pan seperating plastic from metal at the seam and then it sucks air and does all kinds of weird stuff. This problem can be magnified if the fluid is even a tiny bit low and covered up slightly if the fluid is slightly high, THAT IS NOT THE SOLUTION! But it can be a helpful diagnostic tool. Even if the tranny is actually toast they are very cheap to buy good low mile used ones because the engine is usually condemned due to timing chain noise nobody wants or knows how to fix.
Re: 2004 Dakota transmission help [Re: HotRodDave] #2928231
05/29/21 05:30 PM
05/29/21 05:30 PM
JDMopar Offline OP
JDMopar  Offline OP
Yeah.....I originally bought the transmission that is in the truck, to go in a 70 Duster with a 5.7 Hemi swap. I kinda shelved that idea, and ended up putting it in the 4 door Dakota I bought dirt cheap with a bad motor. Trans came out of a 2007 Chrysler Aspen that had 37K miles, and worked like a champ until the other day. We were 3 miles from the end of a 300 mile run the truck has made many times in the last 2 years, so it really surprised me. I bought a remanned 4.7 from Powertrain Products, and have had zero problems in the 16K miles we have put on the truck since we got it going. I appreciate the responses, and will report back what he finds when I get it home to him.
Re: 2004 Dakota transmission help [Re: JDMopar] #2934930
06/19/21 08:57 PM
06/19/21 08:57 PM
JDMopar Offline OP
JDMopar  Offline OP
A little update. I hauled it home from the beach, and took it the trusted transmission shop. He plugged in and pulled the codes, and I forget the numbers...but it showed a shift solenoid malfunction. He cleared the codes, and added almost a quart of fluid and said to drive it and see if it sets another code and turns the light on again. He said it should do it within a hundred miles or so, if it was going to. He said these transmissions are very finicky about being even slightly low of fluid, and that I may get lucky and that caused it. I've run the hell out of it for a little over a hundred miles, and it's still fine. I'm gonna run it some more and see, but so far....so good!
Re: 2004 Dakota transmission help [Re: JDMopar] #2935047
06/20/21 01:33 PM
06/20/21 01:33 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
luck
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 2004 Dakota transmission help [Re: JDMopar] #2935294
06/21/21 01:35 PM
06/21/21 01:35 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
They are only that "finnicky" about fluid level when the filter starts separating.
Re: 2004 Dakota transmission help [Re: HotRodDave] #2935854
06/22/21 11:11 PM
06/22/21 11:11 PM
JDMopar Offline OP
JDMopar  Offline OP
Yeah, he said the same thing. The salvage yard that I bought the trans from is a big, professional operation. They drain fluids and install tags to refill before use. The trans came out of a wrecked 2007 Chrysler Aspen with 37K miles on it, and had probably been sitting for a few years when I bought it in 2013. It then sat sealed up in my shop until 2019 when I installed it in the Dakota, after I ditched the idea of putting the 5.7 Hemi and 545 in my 70 Duster. All that time sitting makes me wonder if the filter separated due to being mostly dry and sitting. I've run the living hell out of it, both on the interstate and around town since he said to drive it, and it has worked flawlessly. I may just go on and get them to fix it, rather than wondering when it will F up again. confused
Re: 2004 Dakota transmission help [Re: JDMopar] #2944931
07/19/21 07:59 PM
07/19/21 07:59 PM
JDMopar Offline OP
JDMopar  Offline OP
Well....the wife and I drove the Dakota on about a 140 mile trip to Charlotte over the weekend. Went down there just fine, with no troubles at all. When we were on the way home, it hiccupped again at around 70 mph and kicked out of OD. A few seconds after it did it, the check engine light came on again. I just slowed down to around 60 mph to keep the RPM's down, and drove it the rest of the way home. It's at the transmission shop now, and they are going to check the fuse box for bad connection to trans, and if that's ok...replace shift solenoid and change fluid and both filters.
Re: 2004 Dakota transmission help [Re: JDMopar] #2945075
07/20/21 10:08 AM
07/20/21 10:08 AM
Buford, GA
Buford, GA
luck
Tim
'71 Charger 383/727
Re: 2004 Dakota transmission help [Re: I_bleed_MOPAR] #2948327
07/28/21 09:35 PM
07/28/21 09:35 PM
JDMopar Offline OP
JDMopar  Offline OP
Just got a call from the shop a while ago, that it's fixed. It was the shift solenoid. I'll pick it up tomorrow. up
Re: 2004 Dakota transmission help [Re: JDMopar] #2949093
07/31/21 10:47 AM
07/31/21 10:47 AM
JDMopar Offline OP
JDMopar  Offline OP
Hopefully.....it's fixed for good now. I drove it 311 miles to the beach yesterday, and ran 80 mph most all the way on the interstate. Never had a problem! boogie The guys at the transmission shop checked the pickup filter that splits, and said it wasn't split or cracked. They still tossed it and installed both filters new. They said there was zero debris in the bottom of the pan, and said they cut the filters apart and zero debris in them either. They put in a factory Mopar Shift solenoid instead of aftermarket, so my guess is that SloJoe and Co. will kill the truck before the transmission messes up again.
Re: 2004 Dakota transmission help [Re: JDMopar] #2950096
08/03/21 05:50 PM
08/03/21 05:50 PM
Buford, GA
Buford, GA
Tim
'71 Charger 383/727
