Can I get a cam recommendation for LA roller 360
#2949974
08/03/21 11:37 AM
08/03/21 11:37 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Yeah, yeah.... Call a cam grinder. I know. I did, and they recommended the same cam I have on my shelf aside for a stroker I am also working on. Seems like too much duration based on what I've read and what is shown in catalogs.So looking for advice here too, to see what falls in line with what as I call a second cam grinder for a second opinion and go back through my "how to build" and "how to hot rod" small mopar books.
Did I mention I don't need anyone to tell me to call a cam grinder?
Engine is a late 360 LA roller motor. Heads are 308's that I am porting to the mopar performance templates. Pistons will be KB107s on SCAT I beams, and a factory CFD cast crank. Intake is a Edelbrock Performer RPM. Doug's headers, with full T/A exhaust. Rest of drivetrain is 727 auto with a PTC converter that stalls at 2400 with my current engine, and 3:23 sure grip 8 3/4 turning 255/60/15 tires. All stock 1971 Challenger.
Looking for a cam that will be a decent all around street cam. Would like more bottom end torque than I have now, but don't want it to completely out of performance on the highway.
Current engine is about 20 years and 200,000 miles old with KB107 in icecream cone shaped cylinder bores, stock rods and crank, unported 308s, Weiand Stealth, headers, and flat tappet cam that I think is 270/270 470/470.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Can I get a cam recommendation for LA roller 360
[Re: Michael Ecks]
#2949976
08/03/21 11:39 AM
08/03/21 11:39 AM
Posts: 4,457 Washington
madscientist
Washington
Who did you call? Don’t be married to catalog numbers.
[Re: madscientist]
#2950134
08/03/21 07:37 PM
08/03/21 07:37 PM
Posts: 6,150 Melbourne , Australia
LA360
270 is @0.050" or adv duration? Adv duration numbers vary, as each manafucturer measures it differently. It's not a good point of comparison
Alan Jones
[Re: Michael Ecks]
#2950137
08/03/21 07:44 PM
08/03/21 07:44 PM
Posts: 1,768 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
...727 auto with a PTC converter that stalls at 2400 with my current engine, and 3:23 sure grip 8 3/4 turning 255/60/15 tires. All stock 1971 Challenger.... I would not go past 225-230 @0.050"...not enough stall and not enough gear, it'll make for a non-responsive throttle and slow moving engine through it's RPM band.
[Re: Michael Ecks]
#2950170
08/03/21 08:51 PM
08/03/21 08:51 PM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
What are the recommendations you got so far? Compression ratio and head flow numbers would help a lot.
[Re: Michael Ecks]
#2950171
08/03/21 08:52 PM
08/03/21 08:52 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I would go 224@ .050, 108lca and with 1.6 rockers about .570 lift if you can get the oem heads to accept that.
Brian Hafliger
[Re: Uberpube]
#2950239
08/03/21 10:44 PM
08/03/21 10:44 PM
Posts: 9,883 MI, usa
dvw
MI, usa
My combo is somewhat similar. 73 Challenger, 360, 9.0-1, LD340, 650 Holley DP,TTI headers and exhaust, ported factory heads. It runs a 220@.050 Crane hyd roller. with 1.6 rocker. 275 60 tire with a 3.55. 2.47 1st 4 speed. Runs on 87 octane. Drives excellent on the street. Has been 12.70s with sticky tires. I'll dig out the cam card.
Doug
