Re: Iron or Aluminum?
[Re: unknown]
#294988
04/22/09 11:43 AM
04/22/09 11:43 AM
Posts: 627 IN
BIG BEAR
IN
Im not familiar with 375 aluminum, but the oversize cam and raised location are doable. Some of our(in stock)iron blocks have the roller cam option.At their current location you can fit a 4.5+ stroke no problem.sorry 4.75+
[Re: BIG BEAR]
#294989
04/22/09 11:43 AM
04/22/09 11:43 AM
Posts: 1,107 Quebec, Canada
Diablo
Quebec, Canada
Does you're iron block have the 4.840BS option? Cause thats what i really need, oh with raised cam, mains priority oiling, and a 55 or 66mm cam would be nice ![](/ubbthreads/images/graemlins/smile.gif) Also need the ability to put my 5inch stroke crank in her
[Re: BIG BEAR]
#294991
04/22/09 11:51 AM
04/22/09 11:51 AM
Posts: 622 sing sing
unknown
sing sing
If you need that kind of power and that strenght why not use our iron block, I know its heavy, but it's less than half the cost?
I did talk to you guys at Norwalk 2 years ago and looked at your blocks you had on display, very nice stuff. But I think I would come up short on HP even with the best heads on the market with 4.80 bore center blocks and heads. With the mopar pro-stock heads 1300 - 1400 HP should not be a problem.
[Re: BIG BEAR]
#294992
04/22/09 11:57 AM
04/22/09 11:57 AM
unknown
sing sing
Sorry, 357-T6 ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: BIG BEAR]
#294995
04/22/09 12:09 PM
04/22/09 12:09 PM
unknown
sing sing
the engine that Koffels just rebuilt was making that kind of horse on motor but I believe they are going to throw some juice at it.
Not to say it cant be done, but man o man 1300-1400 HP NA race gas with 4.80 bore centers. Im not sure the B1-TS heads with 4.80 BS could support those numbers. ![](/ubbthreads/images/graemlins/shruggy.gif)
#295002
04/22/09 04:41 PM
04/22/09 04:41 PM
Posts: 75,145 A Banana Republic near you.
JohnRR
an unskirted block ala chevy with splayed main bolts would offer better oil control in the pan area
Then they will have to make a pan and timing cover for it also ???
[Re: JohnRR]
#295003
04/22/09 05:23 PM
04/22/09 05:23 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
the buyer for $1500 blocks will be buying $599 dollar cranks and $369 rods .
That's probably true. But, there are guys who sell a lot of $899 heads, $599 dollar cranks, and $369 rods.
And, after spending $$$ on having a block bored/decked/line honed for a buildup, it kinda' frosts me to think that by changing (after machining the block... ) to better heads and roller cam, I should have stepped up to a short fill in the jackets, aluminum caps, and a girdle so I could go even farther yet.
Yeah, I'd be in the market for a good $1500 block if I were starting over.
Oh, BTW, if the OP wants to get down with the low-budget block, I'd have cared less if it had internal oil pickup (bet most guys buying the block wouldn't use it); would expect a lot of guys would like a second set of holes drilled in the bellhousing flange. How many guys run glides - quite a few.
![](/ubbthreads/images/graemlins/Twocents.gif)
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
