Page 2 of 6 1 2 3 4 5 6
Re: Iron or Aluminum? [Re: BIG BEAR] #294944
04/21/09 01:19 PM
04/21/09 01:19 PM
an8sec70cuda Offline
The wedge will be in higher demand since there are a lot less people running hemis. Although, it'd be nice to have another hemi block on the market.
The iron block would probably sell better due to the lower cost. Even though the aluminum block is better down the road as far as fixing a window or resleeving, most people just base their decision on initial cost.
I went w/ an aluminum KB block b/c it's likely the last block I'll have to buy. If it gets worn out, I can resleeve it. If it blows up, I can have it repaired. Not to mention the machine work was quality and I did not need to massage much at all to use it right out the box.
I bought mine before the World blocks were available. I heard so many horror stories about the old MP mega blocks machining that wound up costing as much as a KB block to make them useable. CHIP
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Iron or Aluminum? [Re: BIG BEAR] #294945
04/21/09 01:46 PM
04/21/09 01:46 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
All else the same Al blocks make less HP for whatever reasons, enough of a difference that the weight alone will not compensate for the difference. Given the above I would always pic the AL block anyway due to other advantages.
Re: Iron or Aluminum? [Re: 540dust] #294946
04/21/09 02:02 PM
04/21/09 02:02 PM
IN
BIG BEAR Offline OP
BIG BEAR  Offline OP
IN
would you say that the biggest problem with the iron
blocks would be the repairablity?
Re: Iron or Aluminum? [Re: BIG BEAR] #294947
04/21/09 02:09 PM
04/21/09 02:09 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
I would choose AL because of the ability to repair. Even at the higher initial cost sometimes they may be the last block you will ever need. Through a rod through a iron block and it scrap metal.
What i'll be looking at is a Alum or Iron block with a 4.840BS option in the future.
Re: Iron or Aluminum? [Re: BIG BEAR] #294948
04/21/09 02:10 PM
04/21/09 02:10 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
There may be a market yet for a cheap, iron, unskirted(less iron and lighter), dowled 2-bolt main (9/16" stud), low-deck big-block, 4.56" bore (cast them larger), even with a GM bellhousing. Simplify the casting e.g. no fuel pump boss, or internal oil pick-up, etc... Put the feelers out in a thread like this. Or read thru the 440Source proposed block thread archieved in here. If the cost were low enough I'd guess you'll win-over the alloy block people 'cause it ain't cheap to properly repair/resleeve an aluminium block.
Post deleted by Defbob [Re: BIG BEAR] #294949
04/21/09 02:14 PM
04/21/09 02:14 PM
Re: Iron or Aluminum? [Re: Diablo] #294950
04/21/09 02:14 PM
04/21/09 02:14 PM
IN
BIG BEAR Offline OP
BIG BEAR  Offline OP
IN
nice
Re: Iron or Aluminum? [Re: HardcoreB] #294951
04/21/09 02:17 PM
04/21/09 02:17 PM
IN
BIG BEAR Offline OP
BIG BEAR  Offline OP
IN
why not just use a chevy block, fill in the head bold holes and drill and tap new ones, and use a mopar head? Or just get an Arias
Re: Iron or Aluminum? #294952
04/21/09 02:19 PM
04/21/09 02:19 PM
IN
BIG BEAR Offline OP
BIG BEAR  Offline OP
IN
the repaired block that Scott fixed is scheduled this weekend so hopefully they will get some good runs.
Re: Iron or Aluminum? [Re: BIG BEAR] #294953
04/21/09 02:24 PM
04/21/09 02:24 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
deckheight, bore spacing, rocker oiling, lifter positioning. etc...I don't understand. Are you speaking as a MOPAR purist? Does your racecar have to have an 8 3/4 and a 727?
Re: Iron or Aluminum? [Re: HardcoreB] #294954
04/21/09 02:29 PM
04/21/09 02:29 PM
IN
BIG BEAR Offline OP
BIG BEAR  Offline OP
IN
Im speaking as a manufacturer, I'll make what will sell, but I dont think that there is enough money to justify the cause, or could I be wrong?
Post deleted by Defbob [Re: HardcoreB] #294955
04/21/09 02:30 PM
04/21/09 02:30 PM
Re: Iron or Aluminum? [Re: HardcoreB] #294956
04/21/09 02:31 PM
04/21/09 02:31 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
cheap, iron, unskirted(less iron and lighter), dowled 2-bolt main (9/16" stud), low-deck big-block, 4.56" bore (cast them larger), even with a GM bellhousing. Simplify the casting e.g. no fuel pump boss, or internal oil pick-up, etc... cheap
Limited market for larger B/S unique combinations...However, there are plentiful supplies of top-ends that can push 800-1000HP especially with a power adder. Something these features should tolerate.
Re: Iron or Aluminum? #294957
04/21/09 02:34 PM
04/21/09 02:34 PM
IN
BIG BEAR Offline OP
BIG BEAR  Offline OP
IN
what do you think about a 4.84 bs block, would people be after it?
Re: Iron or Aluminum? [Re: HardcoreB] #294958
04/21/09 02:35 PM
04/21/09 02:35 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Not you Fred, was talking to BB...much love coming from me to you. It almost sounded like a fecesious response to my idea of intergrading a couple of better features into a proposed item.
Re: Iron or Aluminum? [Re: BIG BEAR] #294959
04/21/09 02:41 PM
04/21/09 02:41 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Just make an aluminum big block dodge for 1500 bucks and I guarantee you'll be laughing all the way to the bank $$ $$ $$
Re: Iron or Aluminum? [Re: BIG BEAR] #294960
04/21/09 02:42 PM
04/21/09 02:42 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
IMO you already market a HIGH-END block with good quality. How is that one selling for you? Even the B1/PSO and Predator heads are currently built around a 4.8" B/S. A larger B/S block is still a smaller market IMO and this is not the time (economically speaking) to build it assuming others will manufacter/engineer parts compatible. It's been nice chatting but, I gotta go...
Re: Iron or Aluminum? [Re: HardcoreB] #294961
04/21/09 02:42 PM
04/21/09 02:42 PM
IN
BIG BEAR Offline OP
BIG BEAR  Offline OP
IN
sorry to come aross that way, I'm just saying I dont think it would be a profitable venture, but as I sayed I could most certainly be wrong.
Post deleted by Defbob [Re: an8sec70cuda] #294962
04/21/09 02:43 PM
04/21/09 02:43 PM
Re: Iron or Aluminum? #294963
04/21/09 02:47 PM
04/21/09 02:47 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
"read thru the 440Source proposed block thread archieved in here"
The response for a cheap block was overwhelming.
