Where to get a good distributor cap? #2947496
07/26/21 07:39 PM
07/26/21 07:39 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
For a mopar distributor? These unribbed ones dont work well at all.
Re: Where to get a good distributor cap? [Re: Hot 340] #2947498
07/26/21 07:41 PM
07/26/21 07:41 PM
Kirkland, Washington
Pacnorthcuda Offline
I just bought another Accel 8320. Tan in color, brass terminals, they always serve me well.
Re: Where to get a good distributor cap? [Re: Pacnorthcuda] #2947505
07/26/21 07:59 PM
07/26/21 07:59 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
is it ribbed?
Re: Where to get a good distributor cap? [Re: Hot 340] #2947506
07/26/21 08:03 PM
07/26/21 08:03 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Accels for me too. Never had an issue with them.
I believe they are ribbed, can't recall the last time I had one off !
Re: Where to get a good distributor cap? [Re: Hot 340] #2947641
07/27/21 01:48 AM
07/27/21 01:48 AM
AndyF Offline
AndyF  Offline
I just threw some new, original caps away. I took them to the last swap meet and tried to sell them for a few bucks each but nobody was interested. One guy wanted to know if they were for a dual point distributor. I have no idea if dual points used a different cap, not sure why they would so I told him I didn't know.
Re: Where to get a good distributor cap? [Re: AndyF] #2947647
07/27/21 02:57 AM
07/27/21 02:57 AM
The cap and rotor are different between the stock single point and stock dual point distributors, the dual point caps have the carbon from the coil wire going to the flat rotor. The single point caps have a brass pointed thingy( CRS proper name (blush) and the rotors have a flexable thin blade that pushes up against the brass contact scope shruggy
As far as the Accel caps, the new ones, both types, are smooth inside now whiney puke
Re: Where to get a good distributor cap? [Re: Cab_Burge] #2947672
07/27/21 08:34 AM
07/27/21 08:34 AM
VA
dragon slayer Offline
VA
Chrysler caps whether point or electronic also have a cut out notch in cap for phasing on the tab on the vacuum can. Prestolite dual points have a molded protrusion that fits into the cutout of the clamp bracket, besides the differences Cab mentioned.
Re: Where to get a good distributor cap? [Re: dragon slayer] #2947833
07/27/21 03:41 PM
07/27/21 03:41 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
NAPA ECH M020
Copper, not ribbed, vented, USA.
Re: Where to get a good distributor cap? [Re: CMcAllister] #2947835
07/27/21 03:48 PM
07/27/21 03:48 PM
BDW Offline
BDW  Offline
Forgive my ignorance, what is the rib, and why does it matter?
Re: Where to get a good distributor cap? [Re: BDW] #2947865
07/27/21 05:39 PM
07/27/21 05:39 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Ribs inside the cap to help prevent crossfire.
I've used them both ways. As long as the cap is vented and the rest of the secondary ignition is in good shape, there shouldn't be an issue if they aren't there.
Re: Where to get a good distributor cap? [Re: BDW] #2947866
07/27/21 05:42 PM
07/27/21 05:42 PM
Internal ridges between the terminals, it’s sometimes used to reduce flashover arcing from the rotor to a WRONG cylinder’s terminal. I’ve been using unribbed caps with a MSD for 16 years without a problem.
Re: Where to get a good distributor cap? [Re: AndyF] #2947953
07/27/21 10:27 PM
07/27/21 10:27 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
I'd taken them if I'd seen them.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Where to get a good distributor cap? [Re: CMcAllister] #2948121
07/28/21 11:49 AM
07/28/21 11:49 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Originally Posted by CMcAllister
NAPA ECH M020
X 2
NAPA is the only cap and rotor I buy. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Where to get a good distributor cap? [Re: I_bleed_MOPAR] #2948801
07/30/21 11:45 AM
07/30/21 11:45 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
caps with aluminum terminals are the least desirable but will work. most performance caps are brass. the only copper caps i've found are blue in color and although copper is the best people won't buy the caps because of their color. to my knowledge nobody makes a ribbed cap anymore. i'm not certain the ribs are a big deal but the newer caps do have the vent which i like.
Re: Where to get a good distributor cap? [Re: lewtot184] #2948818
07/30/21 12:32 PM
07/30/21 12:32 PM
Buford, GA
Buford, GA
Echlin ECH AL124 pic shows black cap with ribs and looks like aluminum terminals? while specs say brass but no vent. The ECH MO20 pic shows a tan cap, no ribs, and a vent with brass terminals which is listed in the specs. work
Tim
'71 Charger 383/727
Re: Where to get a good distributor cap? [Re: I_bleed_MOPAR] #2949068
07/31/21 09:01 AM
07/31/21 09:01 AM
rust belt
Moparite Online content
Moparite  Online Content
rust belt
The ribs also help in damp locations. Had an issue where rain water would fall on the back of the motor and the steam would get in to the cap and cross fire. Get the Accel 8320 you won't be sorry!
Re: Where to get a good distributor cap? [Re: Moparite] #2949113
07/31/21 11:42 AM
07/31/21 11:42 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
all the new 8320's i have don't have ribs anymore, but they do have a vent.
Re: Where to get a good distributor cap? [Re: lewtot184] #2949159
07/31/21 02:08 PM
07/31/21 02:08 PM
moparx Offline
moparx  Offline
if one were to add a vent hole to a B/RB cap, how large a hole should be added, and where would be the best location for that hole ?
could the hole be added to the side of the cap ?
beer
Re: Where to get a good distributor cap? [Re: I_bleed_MOPAR] #2949222
07/31/21 06:35 PM
07/31/21 06:35 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Tim
ECH MO20 is an excellent cap along with rotor ECH MO3000
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Where to get a good distributor cap? [Re: bee1971] #2951539
08/08/21 06:01 AM
08/08/21 06:01 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
Accell here with the brass terminals, HI-6 ignition burns up the aluminium terminal caps in short order.
