Crank sprocket loose fit on crank. Any easy fixes? #294833
04/21/09 10:23 AM
04/21/09 10:23 AM
Charlotte, NC
446acuda Offline OP
446acuda  Offline OP
Charlotte, NC
I have a K1 crank that is undersized by .002-.003 on the area where the crank sprocket fits. I tried an old DC gear, a cloyes gear and a Rollmaster and none are even close to a light press fit. I should have caught this when I bought the crank but too late now since K1 isn't even owned by Carillo anymore. Any easy fixes for this?... like a gear for another brand of engine that can be honed to fit
Re: Crank sprocket loose fit on crank. Any easy fixes? [Re: 446acuda] #294834
04/21/09 10:29 AM
04/21/09 10:29 AM
WA 98043
thecarfarmer Offline
WA 98043
Loctite?
-bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: Crank sprocket loose fit on crank. Any easy fixes? [Re: thecarfarmer] #294835
04/21/09 10:35 AM
04/21/09 10:35 AM
Charlotte, NC
446acuda Offline OP
446acuda  Offline OP
Charlotte, NC
that would be nice but I need a fix that will get a light press fit so that I don't have to worry about sprocket runout that will wear out the chain. BB Chevy is the same sprocket but unfortunately has a bigger inside diameter.
Re: Crank sprocket loose fit on crank. Any easy fixes? [Re: 446acuda] #294836
04/21/09 10:39 AM
04/21/09 10:39 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I beleive when you install the balancer, it will sandwich the gear in place and hold it in place.
Re: Crank sprocket loose fit on crank. Any easy fixes? [Re: 446acuda] #294837
04/21/09 10:40 AM
04/21/09 10:40 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Doesn't the hub on the balancer pin that gear up against the crank anyway? I know mine all have. I have had a couple that went on loose and I never had a chain/sprocket failure of any kind.
Re: Crank sprocket loose fit on crank. Any easy fixes? [Re: 446acuda] #294838
04/21/09 10:44 AM
04/21/09 10:44 AM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
I'll probably get for this cuz it's way too cheep a fix; I had the same problem with a chain and gear set I bought from a member years ago ( don't remember his name so it doesn't matter now )crank sprocket was loose (maybe that was why he was selling it unused and cheep), not one to give up, I took a center punch and pricked the crank to upset some materail to tighten up the fit (poor mans Knurel); it's tight, it works, case closed.
Re: Crank sprocket loose fit on crank. Any easy fixes? [Re: RonP] #294839
04/21/09 10:48 AM
04/21/09 10:48 AM
Charlotte, NC
446acuda Offline OP
446acuda  Offline OP
Charlotte, NC
I'd probably let it slid if it was race only but I plan to put quite a few street miles so I think that I really need a fix that is going to minimize sprocket runout.
Re: Crank sprocket loose fit on crank. Any easy fixes? [Re: 446acuda] #294840
04/21/09 10:59 AM
04/21/09 10:59 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If it's too loose,run an inside knurl on the gear or center punch about a 1/2 dozen spots on the inside of the gear or on the crank snout.You can also use retainer seal(Permatex or similar).The balancer hub will lock it in place
Re: Crank sprocket loose fit on crank. Any easy fixes? [Re: JBurch] #294841
04/21/09 11:08 AM
04/21/09 11:08 AM
an8sec70cuda Offline
I've done the center punch method JBurch and BG mentioned on a few motors and never had a problem. It tightens them up good. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Crank sprocket loose fit on crank. Any easy fixes? [Re: 446acuda] #294842
04/21/09 11:33 AM
04/21/09 11:33 AM
Charlotte, NC
446acuda Offline OP
446acuda  Offline OP
Charlotte, NC
Thanks all ! the punch method is just the kind of easy fix I was looking for.
