Page 2 of 3 1 2 3
Re: How to replace shift shaft seal on 727 trans? [Re: Snailpower] #29476
09/03/06 05:14 PM
09/03/06 05:14 PM
The deep pan is not the way to fix your problem! The seals are easy to change, just get the (KD) tool (Anderwh) listed and do it in the car. Drain some fluid out prior to doing it so you don't get covered in fluid. If you don't want to buy the tool, use a small screwdriver to pry out the old seal and a deep socket to hammer in the new seal.
Next time you need a small seal for your transmission, go to you local trans shop, they should have plenty of them.
Re: How to replace shift shaft seal on 727 trans? [Re: Kirk_Ingram] #29477
09/03/06 05:15 PM
09/03/06 05:15 PM
A deeper pan that has more capacity .... filled at the same height as a stock pan ?
How many larger capacity engine oil pans are approached this way ?
REcalibrate your dip-stick then.
And very true .... putting a deep pan on to avoid leakage is a band-aid - and it IS more proper to FIX the ailment. But to some people that are DIY ... this job could be over-their-heads.
Just my
Re: How to replace shift shaft seal on 727 trans? #29478
09/03/06 07:20 PM
09/03/06 07:20 PM
Minnesota
THBear Offline
THBear  Offline
Minnesota
We use the KD tool at our shop and it works great. There is a remover and installer included with the tool. The only part you have to remove is the shift levers. You can replace the smaller seal at the same time but you have to be careful after you remove the e-clip so that the shaft doesn't drop down into the pan. If it does it's not the end of the world, you just have to pull the pan off.
Re: How to replace shift shaft seal on 727 trans? [Re: THBear] #29479
09/03/06 09:56 PM
09/03/06 09:56 PM
Sacramento, CA
cal_gecko Offline OP
Sacramento, CA
I'll make a trip to a local tool store and see if they have this tool you guys are talking about.. if not, I'll order it from that website.
The other seal that you've mentioned, the kickdown seal... any suggestions where to get that?
Re: How to replace shift shaft seal on 727 trans? [Re: cal_gecko] #29480
09/03/06 10:53 PM
09/03/06 10:53 PM
kd seal ? ...stop by any trans shop. They should have a bunch of them. Those seals are very rarely changed by most rebuilders.
Re: How to replace shift shaft seal on 727 trans? [Re: cal_gecko] #29481
09/04/06 02:14 AM
09/04/06 02:14 AM
Carmichael, CA
NotEnufGarage Offline
Carmichael, CA
I may be running by a friends transmission shop tomorrow. If so, I'll see if he has a seal.
I'll PM you if I get one.
'70 Charger FE5 Daytona Clone 451/727/D60
'70 Challenger FM3 440/833/3.55SG
'79 Ramcharger SE 360
'89 Shelby Dakota
‘06 PT Cruiser GT Convertible
‘07 Charger R/T Daytona
‘10 Ram 1500 ST Crew Cab
Yes, I'm a Dodge Boy. Verstehen?
Re: How to replace shift shaft seal on 727 trans? [Re: NotEnufGarage] #29482
09/04/06 03:26 AM
09/04/06 03:26 AM
Sacramento, CA
Sacramento, CA
Awesome, thanks! I already have the shift shaft seal.. .just need the kickdown seal
Re: How to replace shift shaft seal on 727 trans? [Re: Kirk_Ingram] #29483
09/04/06 02:29 PM
09/04/06 02:29 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
And the "band-aid fix" is to fill the trans with a couple quarts less.
Not a good idea. The TF, unlike the engine, can suck air if the VB-to-case mating surface is exposed to the air.
Re: How to replace shift shaft seal on 727 trans? [Re: John_Kunkel] #29484
09/04/06 04:20 PM
09/04/06 04:20 PM
I have always wondered about that....but if that was a major "issue" - why wouldn't the OEM have put some O-rings or a gasket in there?
Re: How to replace shift shaft seal on 727 trans? [Re: John_Kunkel] #29485
09/04/06 06:03 PM
09/04/06 06:03 PM
Sacramento, CA
K
Kirk_Ingram Offline
super street
Kirk_Ingram  Offline
super street
K
Sacramento, CA
Good point! -K
Death or Glory...it's just another story.
Re: How to replace shift shaft seal on 727 trans? #29486
09/04/06 06:05 PM
09/04/06 06:05 PM
Rio Linda, CA
Rio Linda, CA
It's not a major issue if the mating surface stays submerged in fluid as it should with the correct fluid level.
Re: How to replace shift shaft seal on 727 trans? [Re: cal_gecko] #29487
09/06/06 01:11 AM
09/06/06 01:11 AM
Carmichael, CA
Carmichael, CA
Sorry - my buddy usually gets them in seal or rebuild kits and he didn't have any in stock.
I've got a /6 904 you could take one out of, if you want to try reusing a used one.
'89 Shelby Dakota
Re: How to replace shift shaft seal on 727 trans? [Re: NotEnufGarage] #29488
09/06/06 10:17 AM
09/06/06 10:17 AM
Northern CA
streetkit Offline
streetkit  Offline
Northern CA
Mark,
Last time I needed one, Autozone (of all places) had them in stock.
1973 Dodge D100
Re: How to replace shift shaft seal on 727 trans? [Re: streetkit] #29489
09/17/09 03:49 AM
09/17/09 03:49 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I did this last year. Used a tool off ebay for less than $20
Something like this one
http://cgi.ebay.com/ebaymotors/KD-TOOLS-...d=p4506.c0.m245
I think I have pictures of the install posted a while back too. I had to use a C clamp because of the space limitations but I fixed it in less than an hour. No need to drop the pan.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: How to replace shift shaft seal on 727 trans? [Re: cal_gecko] #29490
09/17/09 04:19 AM
09/17/09 04:19 AM
So Cal
So Cal
the shift shaft seal on the SuperCoupe is leaking pretty bad..
This is pretty bad...
Cleaned off.
Tool ready to remove seal...
Clamp to put pressure on seal while I turn the threads into the seal
After the tool takes hold of the seal you put the bolt into the top of the tool to pull the seal out....
click the picture for a larger view.
here is the picture of the seal removed
A closer look...
The new seal
New seal being installed with tool and clamp.
Linkage re installed.
Re: How to replace shift shaft seal on 727 trans? #29491
09/17/09 05:09 AM
09/17/09 05:09 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I just did this job on my son's Ramcharger yesterday. It took about an hour and a half. That included dropping the pan and valvebody, adjusting the bands, new filter. I find just about any old Mopar I buy needs this seal replaced. (and the trans always have a new pan gasket as that is what most people think is leaking).
Sheldon
Re: How to replace shift shaft seal on 727 trans? [Re: cal_gecko] #2324555
06/21/17 07:50 AM
06/21/17 07:50 AM
Spokane, WA
FastbackJon Offline
FastbackJon  Offline
Spokane, WA
I am looking at replacing the shift shaft seal from the top with the extractor tool in my 1966 Charger 727.
I am hesitant in taking the two levers off (gear and throttle) from the shift shaft, not knowing if they are keyed are not. Or should I worry about this?
The throttle lever appears to be keyed but the gear lever, I can't tell. Will it just go back on the same as it came off and then I can just make minor adjustments to the horizontal rod to change shift selector (gear) position?
Thanks!
Re: How to replace shift shaft seal on 727 trans? [Re: FastbackJon] #2324578
06/21/17 09:43 AM
06/21/17 09:43 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Thanks!
they can only go on one way,youll see that when you remove them.
Re: How to replace shift shaft seal on 727 trans? [Re: HealthServices] #2324647
06/21/17 12:27 PM
06/21/17 12:27 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Nice instructive post, bow beer
Re: How to replace shift shaft seal on 727 trans? [Re: FastbackJon] #2324779
06/21/17 03:36 PM
06/21/17 03:36 PM
Rio Linda, CA
Rio Linda, CA
Various shift levers and TP levers.
Page 2 of 3 1 2 3
