Re: 1974 E-Body Cuda to 1971 Rear Bumper Conversion
[Re: Cuda 440-6]
#2948248
07/28/21 05:35 PM
07/28/21 05:35 PM
Posts: 294 Maryland
MoparMike1974
Maryland
I will be watching this thread because im cloning my 74 to a 71. I think all you need is to swap the bumper and the correct brackets and it should be a bolt on deal. I have some original bumper brackets out in the garage, I will see if I can find some part numbers.
Im going the full clone route on mine. Swapping the tail panel, bumpers, quarters, fenders, grill....everything.
As soon as this hail/rain storm passes I will try to run out and look for part numbers.
[Re: Cuda 440-6]
#2949578
08/02/21 01:26 AM
08/02/21 01:26 AM
Posts: 294 Maryland
MoparMike1974
Maryland
I also have a thread running on this same subject on the E-Bodies Only site. Several of the guys in that thread are suggesting I will still need to modify (Drill, Cut, and Weld) the '72 Brackets to bring the Bumper in lower and tighter with less gap. My plan is to drill new holes in the Brackets above the existing holes to mock up the fitting by hopefully dropping the Bumper enough to fit better. Depending on how this looks and if I want to still pull the Bumper in tighter, I'll take some Bracket angle measurements before cutting and weld them back back together.
I would ask what the difference is on a 71 to 72 as far as the body goes. I really think the difference would be the bumper itself and the brackets. I don't see why it wouldn't fit correctly just by swapping the brackets and bumper.
