Re: Sonoma
[Re: Alan Prusiensky]
#2947992
07/28/21 01:39 AM
07/28/21 01:39 AM
Posts: 43,283 Bend,OR USA
Cab_Burge
If you ain't testing and learning your going backwards, standing still because every one else is testing I'm surprised you don't have data logging or a race pack to read the EGT. I have a set of headers on my S/P car that ended up with O2 sensor bungs in all 8 pipes to do some dyno testing years ago on a customers B1 engine that we dyno tested in Boise ,ID. 7 or 8 yrs ago. The dyno operator insisted on us using them (8 O2 sensors) without thinking that motor had a cast single four barrel B1 intake with a single carb. It did make 920 KP at 7200 RPM with a goof up custom made Damn Best 1450 CFM Dominator type carb Live and learn Good on you guys for keeping the faith on using the Mopar brand 99 Hemi motors still Keep up the good work
Re: Sonoma
[Re: JMCarter]
#2948001
07/28/21 05:21 AM
07/28/21 05:21 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I don’t follow pro stock like I used to but still follow your progress. It’s a lot tougher with only the three qualifying passes and recently you have only been getting two because of an issue. What happened to the second car that was supposed to be there at this race. I thought I read you would have both cars. Good luck and thanks for updating us.
Re: Sonoma
#2948113
07/28/21 11:35 AM
07/28/21 11:35 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
It's great to hear from those who are hands on fighting the fight, rejuvenating and stretching the very soul of auto racing. These are the best of days.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Sonoma
[Re: moparx]
#2948182
07/28/21 02:55 PM
07/28/21 02:55 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
Please keep posting Allen, I only watch PS to see how you are doing
