Challenger drive shaft length? #2947813
07/27/21 02:28 PM
07/27/21 02:28 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Hi, I have a 70 Challenger T/A 340 4speed. I'm getting a vibration above 65mph. Looking at the car from underneath I see that my driveshaft may not be correct and could be the cause of the problem. My driveshaft is 47". A buddy has a similar car and his driveshaft is 49 3/8". Is there a known correct length for the car? Thanks
1970 Dodge Challenger T/A
Re: Challenger drive shaft length? [Re: jeff968] #2947829
07/27/21 03:11 PM
07/27/21 03:11 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
It's in your service manual. You do have one?
Re: Challenger drive shaft length? [Re: GomangoCuda] #2947839
07/27/21 04:07 PM
07/27/21 04:07 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
I do, the yellow cover. i will check . Thx
Re: Challenger drive shaft length? [Re: jeff968] #2947958
07/27/21 10:38 PM
07/27/21 10:38 PM
GomangoCuda Offline
GomangoCuda  Offline
your numbers don't look right. Near as i can tell from the parts manual, it should be 45.85" with 7290 joints or 45.79 with 7260 joints. Are you measuring center to center? Your buddy might have a 904 trans or a smaller rearend than yours. Either would need a longer driveshaft than yours. Even spring arch, ride height makes a difference.
Safest way is to measure what you need and go with it. Lot of tolerance in these old cars and over 50 years of people interchanging parts that are not exactly correct.
Or not even close to correct. runaway
