1985 w150 sliding rear window/ gasket
#2947389
07/26/21 03:02 PM
07/26/21 03:02 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
Does anybody have a picture of a factory sliding rear window for an 80s w150? Trying to determine if mine is original or aftermarket. Also, does anybody make a rear window gasket for one with the chrome trim that pushes in? I can only find replacements for aftermarket windows without the trim. Thanks
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: 1985 w150 sliding rear window/ gasket
[Re: 73cuda340]
#2947521
07/26/21 08:34 PM
07/26/21 08:34 PM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
Nobody makes the gasket for the factory slider.
[Re: Guitar Jones]
#2947585
07/26/21 10:33 PM
07/26/21 10:33 PM
73cuda340
clarks summit pa
Ok thanks. Are the gaskets that much different for the aftermarket sliders?
[Re: 73cuda340]
#2947759
07/27/21 12:07 PM
07/27/21 12:07 PM
Posts: 1,819 Middle of A Field
OrangeProwler
Middle of A Field
Ok thanks. Are the gaskets that much different for the aftermarket sliders? From what I remember yes. I can't remember and I haven't verified this but, I think someone used either both the slider and gasket for a 1994-1996 Ford F-150 application but, don't hold me to it as I'm uncertain. I thought I read it somewhere but, can't remember if it was even right.
[Re: larrymopar360]
#2947846
07/27/21 04:26 PM
07/27/21 04:26 PM
Guitar Jones
You can get the aftermarket sliders and gaskets but not the gasket for the factory slider, went through that a couple years ago on my '92. That is why it has a regular rear window in it now and yeah, it's the same as some Ford application. I never used the slider anyway.
[Re: larrymopar360]
#2947870
07/27/21 05:47 PM
07/27/21 05:47 PM
73cuda340
clarks summit pa
Only for the standard rear windows and the aftermarket rear slider that they sell.
[Re: 73cuda340]
#2947883
07/27/21 06:31 PM
07/27/21 06:31 PM
Posts: 15,945 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Only for the standard rear windows and the aftermarket rear slider that they sell. That's too bad. I just checked Ebay and no NOS ones right now.
Facts are stubborn things.
[Re: 73cuda340]
#2948332
07/28/21 09:41 PM
07/28/21 09:41 PM
Posts: 8,504 Candler,NC / Myrtle Beach, SC
JDMopar
Are you looking for the rubber just for the sliding parts of the window, or the whole gasket? Reason I ask, is I used to have an 84 D350 with a solid glass, and a friend gave me a sliding rear window. I had a glass guy come swap it out, and he reused the same gasket that was around the perimeter opening. Of course, this was about 1990 when the truck wasn't very old.
[Re: JDMopar]
#2948798
07/30/21 11:27 AM
07/30/21 11:27 AM
73cuda340
clarks summit pa
Im looking for the whole gasket. Maybe I'll just try ordering a regular one then and give it a try.
[Re: 73cuda340]
#2948996
07/30/21 10:09 PM
07/30/21 10:09 PM
Guitar Jones
[Re: JDMopar]
#2949103
07/31/21 11:22 AM
07/31/21 11:22 AM
Posts: 4,161 Canada -- Posts: 4034 -Registe...
5thAve
Aftermarket slider windows use the same gasket as glass. The factory slider windows fit differently and use a different gasket.
[Re: 5thAve]
#2949117
07/31/21 11:59 AM
07/31/21 11:59 AM
OrangeProwler
Middle of A Field
A lot of guys say to reuse the factory gasket if you're reinstalling the factory slider anyways[align:right][/align]. The last NOS gasket I saw for a 72-80 dodge truck sold for $200+ shipping about two years ago.
[Re: OrangeProwler]
#2949542
08/01/21 09:11 PM
08/01/21 09:11 PM
73cuda340
clarks summit pa
Does anyone have a picture of a factory slider? I believe mine is original, but I'm not positive
[Re: NITROUSN]
#2950085
08/03/21 05:06 PM
08/03/21 05:06 PM
73cuda340
clarks summit pa
Does anyone have a picture of a factory slider? I believe mine is original, but I'm not positive Why do you not just post the inside and outside pictures of your slider? I'll try, but I can never get pictures to work on a post.
