PCV vacuum source. #2947570
07/26/21 10:01 PM
07/26/21 10:01 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
I sent Dom my BX4 main body to build me a carb using all BLP parts. I run a pcv valve and the BLP base plate he’s using has no provision for one. Should I put the port in my Super Sucker spacer or in the intake or will it matter?
Thanks.
Re: PCV vacuum source. [Re: justinp61] #2947573
07/26/21 10:07 PM
07/26/21 10:07 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i would add it to the spacer .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: PCV vacuum source. [Re: tex013] #2947596
07/26/21 10:47 PM
07/26/21 10:47 PM
Tex
iagree up wrench
Re: PCV vacuum source. [Re: justinp61] #2947598
07/26/21 10:50 PM
07/26/21 10:50 PM
Boise
Moparteacher Offline
Boise
You want it up front by the primaries. Place it in back at the secondary's and you might find cylinders near the back of the block running lean at idle. Although with a 4-hole idle circuit it may be a mute point....nevermind.
Re: PCV vacuum source. [Re: Moparteacher] #2947620
07/26/21 11:47 PM
07/26/21 11:47 PM
Washington
madscientist Offline
Washington
It needs to hook to the ack of the carb. Hooking to a spacer makes it just a vacuum leak. If you have two carbs it should be hooked to both of them. Drill the base plate out to 1/8 pipe and put a brass fitting in there. It’s easy to do.
Re: PCV vacuum source. [Re: Cab_Burge] #2947640
07/27/21 01:24 AM
07/27/21 01:24 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Tex
iagree up wrench
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: PCV vacuum source. [Re: BloFish] #2947646
07/27/21 02:36 AM
07/27/21 02:36 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Carb spacer works fine. I have the one on my roadrunner drilled for PCV and vacuum advance. That’s in a 2” 4500 to 4150 spacer. Works great.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: PCV vacuum source. [Re: 68 HEMI GTS] #2947690
07/27/21 09:18 AM
07/27/21 09:18 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
64 Plymouth Savoy
Dana 60
Re: PCV vacuum source. [Re: justinp61] #2947761
07/27/21 12:15 PM
07/27/21 12:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I stopped using mine years ago, why add a diluted oil vapor to your intake charge......
Re: PCV vacuum source. [Re: Thumperdart] #2947804
07/27/21 01:57 PM
07/27/21 01:57 PM
moparx Offline
moparx  Offline
would adding a separator can like the ones available for late model gen 3 challengers and chargers filter out the oil vapor ?
beer
Re: PCV vacuum source. [Re: moparx] #2947806
07/27/21 02:09 PM
07/27/21 02:09 PM
Rittman Ohio
Rittman Ohio
beer
I use one of those clear Fram fuel filters inline between the carb and PCV and it traps a lot of oil. I change it a few times a year. twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: PCV vacuum source. [Re: moparx] #2947810
07/27/21 02:22 PM
07/27/21 02:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I ran a home made oil separator but still had residual in the intake runners......
Re: PCV vacuum source. [Re: Thumperdart] #2947840
07/27/21 04:12 PM
07/27/21 04:12 PM
W. Kentucky
W. Kentucky
I've always ran one as I don't run evac tubes. Plus it made 3 HP on the dyno with it hooked up. biggrin
I don't see any sign of oil in the carb or intake and there was none on the spacer.
Re: PCV vacuum source. [Re: justinp61] #2947842
07/27/21 04:17 PM
07/27/21 04:17 PM
W. Kentucky
W. Kentucky
Speaking of the spacer, it didn't line up very well with the intake opening. After talking to HVH I did a little grinding. Don't know if it'll help but I feel better. The gasket is matched to the intake.
Re: PCV vacuum source. [Re: justinp61] #2947848
07/27/21 04:30 PM
07/27/21 04:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That does look real clean but I'd prefer none of the controlled vacuum leak stuff just 2 breathers......
Re: PCV vacuum source. [Re: Thumperdart] #2947854
07/27/21 05:12 PM
07/27/21 05:12 PM
W. Kentucky
W. Kentucky
Re: PCV vacuum source. [Re: moparx] #2947861
07/27/21 05:30 PM
07/27/21 05:30 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I put this on my ram. Upr makes the best
Re: PCV vacuum source. [Re: fourgearsavoy] #2948012
07/28/21 07:31 AM
07/28/21 07:31 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I tried a small (about 3" high) cyclonic separator and it collected only a few drops in a couple hundred street miles... so I removed it shruggy
