1985 w150 sliding rear window/ gasket
#2947389
07/26/21 03:02 PM
07/26/21 03:02 PM
Posts: 1,169 clarks summit pa
73cuda340
clarks summit pa
Does anybody have a picture of a factory sliding rear window for an 80s w150? Trying to determine if mine is original or aftermarket. Also, does anybody make a rear window gasket for one with the chrome trim that pushes in? I can only find replacements for aftermarket windows without the trim. Thanks
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: 1985 w150 sliding rear window/ gasket
[Re: 73cuda340]
#2947521
07/26/21 08:34 PM
07/26/21 08:34 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
Nobody makes the gasket for the factory slider.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2947585
07/26/21 10:33 PM
07/26/21 10:33 PM
73cuda340
clarks summit pa
Ok thanks. Are the gaskets that much different for the aftermarket sliders?
[Re: 73cuda340]
#2947759
07/27/21 12:07 PM
07/27/21 12:07 PM
Posts: 1,819 Middle of A Field
OrangeProwler
Middle of A Field
Ok thanks. Are the gaskets that much different for the aftermarket sliders? From what I remember yes. I can't remember and I haven't verified this but, I think someone used either both the slider and gasket for a 1994-1996 Ford F-150 application but, don't hold me to it as I'm uncertain. I thought I read it somewhere but, can't remember if it was even right.
[Re: larrymopar360]
#2947846
07/27/21 04:26 PM
07/27/21 04:26 PM
Guitar Jones
You can get the aftermarket sliders and gaskets but not the gasket for the factory slider, went through that a couple years ago on my '92. That is why it has a regular rear window in it now and yeah, it's the same as some Ford application. I never used the slider anyway.
[Re: larrymopar360]
#2947870
07/27/21 05:47 PM
07/27/21 05:47 PM
73cuda340
clarks summit pa
Only for the standard rear windows and the aftermarket rear slider that they sell.
[Re: 73cuda340]
#2947883
07/27/21 06:31 PM
07/27/21 06:31 PM
Posts: 15,831 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Only for the standard rear windows and the aftermarket rear slider that they sell. That's too bad. I just checked Ebay and no NOS ones right now.
Facts are stubborn things.
[Re: 73cuda340]
#2948332
07/28/21 09:41 PM
07/28/21 09:41 PM
Posts: 8,481 Candler,NC / Myrtle Beach, SC
JDMopar
Are you looking for the rubber just for the sliding parts of the window, or the whole gasket? Reason I ask, is I used to have an 84 D350 with a solid glass, and a friend gave me a sliding rear window. I had a glass guy come swap it out, and he reused the same gasket that was around the perimeter opening. Of course, this was about 1990 when the truck wasn't very old.
[Re: JDMopar]
#2948798
07/30/21 11:27 AM
07/30/21 11:27 AM
73cuda340
clarks summit pa
Im looking for the whole gasket. Maybe I'll just try ordering a regular one then and give it a try.
[Re: 73cuda340]
#2948996
07/30/21 10:09 PM
07/30/21 10:09 PM
Guitar Jones
[Re: JDMopar]
#2949103
07/31/21 11:22 AM
07/31/21 11:22 AM
Posts: 4,142 Canada -- Posts: 4034 -Registe...
5thAve
Aftermarket slider windows use the same gasket as glass. The factory slider windows fit differently and use a different gasket.
[Re: 5thAve]
#2949117
07/31/21 11:59 AM
07/31/21 11:59 AM
OrangeProwler
Middle of A Field
A lot of guys say to reuse the factory gasket if you're reinstalling the factory slider anyways[align:right][/align]. The last NOS gasket I saw for a 72-80 dodge truck sold for $200+ shipping about two years ago.
[Re: OrangeProwler]
#2949542
08/01/21 09:11 PM
08/01/21 09:11 PM
73cuda340
clarks summit pa
Does anyone have a picture of a factory slider? I believe mine is original, but I'm not positive
[Re: NITROUSN]
#2950085
08/03/21 05:06 PM
08/03/21 05:06 PM
73cuda340
clarks summit pa
Does anyone have a picture of a factory slider? I believe mine is original, but I'm not positive Why do you not just post the inside and outside pictures of your slider? I'll try, but I can never get pictures to work on a post.
