Re: PCV vacuum source.
[Re: justinp61]
#2947573
07/26/21 10:07 PM
07/26/21 10:07 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
i would add it to the spacer .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Moparteacher]
#2947620
07/26/21 11:47 PM
07/26/21 11:47 PM
Posts: 4,457 Washington
madscientist
Washington
It needs to hook to the ack of the carb. Hooking to a spacer makes it just a vacuum leak. If you have two carbs it should be hooked to both of them. Drill the base plate out to 1/8 pipe and put a brass fitting in there. It’s easy to do.
[Re: BloFish]
#2947646
07/27/21 02:36 AM
07/27/21 02:36 AM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
Carb spacer works fine. I have the one on my roadrunner drilled for PCV and vacuum advance. That’s in a 2” 4500 to 4150 spacer. Works great.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: justinp61]
#2947761
07/27/21 12:15 PM
07/27/21 12:15 PM
Thumperdart
State of confusion
I stopped using mine years ago, why add a diluted oil vapor to your intake charge......
[Re: moparx]
#2947806
07/27/21 02:09 PM
07/27/21 02:09 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I stopped using mine years ago, why add a diluted oil vapor to your intake charge...... would adding a separator can like the ones available for late model gen 3 challengers and chargers filter out the oil vapor ? I use one of those clear Fram fuel filters inline between the carb and PCV and it traps a lot of oil. I change it a few times a year. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: moparx]
#2947810
07/27/21 02:22 PM
07/27/21 02:22 PM
Thumperdart
State of confusion
I ran a home made oil separator but still had residual in the intake runners......
[Re: justinp61]
#2947842
07/27/21 04:17 PM
07/27/21 04:17 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
Speaking of the spacer, it didn't line up very well with the intake opening. After talking to HVH I did a little grinding. Don't know if it'll help but I feel better. The gasket is matched to the intake.
[Re: justinp61]
#2947848
07/27/21 04:30 PM
07/27/21 04:30 PM
Thumperdart
State of confusion
That does look real clean but I'd prefer none of the controlled vacuum leak stuff just 2 breathers......
