Re: truck oil pan Big Block [Re: moparmarks] #2997329
12/21/21 02:52 PM
12/21/21 02:52 PM
Falcon, CO
Mad-Max Offline
Mad-Max  Offline
Falcon, CO
My 440 came from a 79 Winnebago motor coach - it had a front sump pan, but since I was putting it in a 02 Dakota with a solid front axle I needed a rear sump pan. I got the Milodon 8-quart pan (30890) and pickup tube (18455), plus the dipstick and flex tube kit (22061). I also used the Summit windage tray/pan seal (SUM-G-2339). Being a real off-road machine I fabbed/welded an additional 3/16 plate shield to the bottom. I plugged the OE dipstock hole with a nice plug from Mancini (MREAR279). Diggin' it so far.
Pics -
block dipstick hole plug - tapped right in - no drilling required -
71 Demon (project): 318, A-833od, 8-3/4, 3.23's
14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s
07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler'
52 Willys M-38 "Poncho"
Re: truck oil pan Big Block [Re: Mad-Max] #2997357
12/21/21 05:22 PM
12/21/21 05:22 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Scratchnfortracthn can give you the low down for sure. He gave me a BB truck pan with the exact thing you're asking about. I haven't used it yet. Where are you Mike?
Facts are stubborn things.
