69 road runner coil radio condensor
#2946627
07/24/21 01:27 PM
07/24/21 01:27 PM
Posts: 494 northeast pa
3wracing
northeast pa
my 60 road runner has the ignition coil with radio condensor .What is the purpose of the resistor? mine is shorted out it runs when unhooked but not when its hooked up is it needed
Re: 69 road runner coil radio condensor
[Re: 3wracing]
#2946683
07/24/21 04:18 PM
07/24/21 04:18 PM
Posts: 1,565 tennessee
pushbutton
tennessee
my 60 road runner has the ignition coil with radio condensor .What is the purpose of the resistor? mine is shorted out it runs when unhooked but not when its hooked up is it needed For radio interference.
[Re: pushbutton]
#2946691
07/24/21 04:34 PM
07/24/21 04:34 PM
Posts: 6,248 nowhere
Sniper
nowhere
A condensor is not a resistor, it is a capacitor. When you put your meter on a capacitor to measure it's "resistance" you are charging the capacitor. You need a meter that reads capacitance, not an ohmmeter, to see if it's good or bad. See section 5.2.1 for what you should see when trying to ohm out a capacitor. https://www.apogeeweb.net/electron/how-to-test-a-capacitor.html
[Re: dragon slayer]
#2949054
07/31/21 08:00 AM
07/31/21 08:00 AM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
If you are concerned about stock appearing, just leave the condenser mounted but ditch the wire under the coil in the bracket. That’s what I do on all, unless you are really interested in listening to am radio as you drive around!
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
