Distributor shaft bushing replacement? #2946054
07/22/21 02:40 PM
07/22/21 02:40 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
Good afternoon everyone
On my big block distributor I noticed the shaft bushing is cracked. I am wondering if there any replacements (metal maybe?). I have been looking but cannot find what I need.
Thank you for any help in advance
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Distributor shaft bushing replacement? [Re: TX9H6E4CUDA] #2946064
07/22/21 03:38 PM
07/22/21 03:38 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
It's a collar, not so much a bushing. Normal 1/2" diameter collar ought to work. Might have to drill the hole for the 1/8" pin in it though.
Re: Distributor shaft bushing replacement? [Re: TX9H6E4CUDA] #2946072
07/22/21 03:47 PM
07/22/21 03:47 PM
AndyF Offline
AndyF  Offline
I have a few of those collars still in the factory bag.
Re: Distributor shaft bushing replacement? [Re: AndyF] #2946093
07/22/21 04:50 PM
07/22/21 04:50 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Lowes has these nylon collars in the hardware section. Perfect fit. Hillman is the brand name. Sorry, don't have the part number in front of me.
'63 Dodge 330
11.19 @ 121 mph
Re: Distributor shaft bushing replacement? [Re: TX9H6E4CUDA] #2946098
07/22/21 05:29 PM
07/22/21 05:29 PM
AndyF Offline
AndyF  Offline
Here is what the factory replacement kit looks like.
Re: Distributor shaft bushing replacement? [Re: AndyF] #2946354
07/23/21 01:24 PM
07/23/21 01:24 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
From another thread on here, here is the the Hillman part numbers:
"On the package, It has H# 880447, also UPC# 0823670839 and Lot# HO3967284."
'63 Dodge 330
11.19 @ 121 mph
Re: Distributor shaft bushing replacement? [Re: GY3] #2946361
07/23/21 01:36 PM
07/23/21 01:36 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Mopar dist kit 2275229 has one in it with shim washers etc. BTW, I have a question. Why did the replacement only have one hole drilled in the plastic collar?
Re: Distributor shaft bushing replacement? [Re: mopars4ever] #2946433
07/23/21 06:34 PM
07/23/21 06:34 PM
New Jersey Bada Bing
bremotorsports Offline
Or, you can go with my Level 1 Service Package, including multiple shims to tighten up the verticle shaft movement and everything else needed for basic service. #877 on my site.
Bill Rolik
bremotorsports@verizon.net
www.billrolikenterprises.com
201-394-5533 Cellular
