Re: 1987 Ram 50 4x4
[Re: cudaman1969]
#2945374
07/20/21 08:49 PM
07/20/21 08:49 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
Thanks for the info on that, put it on the back burner for awhile. I could just make up a box frame using the mustang II front end.?? Realistically, that would probably be easier then what you were purposing. You still might want to measure the length distances under the hood. Could change the entire plan. Gene
Re: 1987 Ram 50 4x4
[Re: poorboy]
#2945426
07/20/21 11:04 PM
07/20/21 11:04 PM
Posts: 8,237 fredericksburg,va
cudaman1969
fredericksburg,va
Thanks for the info on that, put it on the back burner for awhile. I could just make up a box frame using the mustang II front end.?? Realistically, that would probably be easier then what you were purposing. You still might want to measure the length distances under the hood. Could change the entire plan. Gene Being an extended cab I could move the firewall back the needed amount.
Re: 1987 Ram 50 4x4
[Re: trw1982]
#2947166
07/25/21 10:28 PM
07/25/21 10:28 PM
Posts: 856 Southeast Pa.
SALEM1912
Southeast Pa.
Interesting post I have had this '88 sitting at work for 4 years. May look into such a build.
Re: 1987 Ram 50 4x4
[Re: SALEM1912]
#2947173
07/25/21 10:48 PM
07/25/21 10:48 PM
cudaman1969
fredericksburg,va
Thanks for reminding me, I have to call the guy tomorrow on his builds. Do it, mines the same color except an extended cab
