What does this 3 groove crank pulley fit? #2944654
07/18/21 08:18 PM
07/18/21 08:18 PM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
Just curious what applications this pulley would fit. I haven't had much luck in my research but would like to know what the right home for it is so I can send it down the road. Appreciate any help with this. Thanks!
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: What does this 3 groove crank pulley fit? [Re: MadMopars] #2944662
07/18/21 08:45 PM
07/18/21 08:45 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Look closer for numbers.
Re: What does this 3 groove crank pulley fit? [Re: NITROUSN] #2944679
07/18/21 09:18 PM
07/18/21 09:18 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Double belt alt, probably an AC car, with power steering. There is a change in the crankshaft bolt pattern between the years, but I don't remember when that happened.
Finding the numbers on it would tell the story. Probably fits a lot of years, body, & motor configurations.
Re: What does this 3 groove crank pulley fit? [Re: poorboy] #2944785
07/19/21 10:43 AM
07/19/21 10:43 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Quote
I believe it was the early 70's and may? have coincided with the use of cast cranks, Not 100% on that though. I beleieve it was just 1 hole that was moved and easily remedied with a file twocents beer
Re: What does this 3 groove crank pulley fit? [Re: TJP] #2944813
07/19/21 12:40 PM
07/19/21 12:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
'72 was the changeover year for the pulley bolt pattern. Went from asymmetric to symmetric.
Re: What does this 3 groove crank pulley fit? [Re: John_Kunkel] #2944821
07/19/21 12:59 PM
07/19/21 12:59 PM
Tucson AZ,
Tucson AZ,
These are the only numbers I'm seeing... Also, if it helps, it's a symmetrical pattern.
Re: What does this 3 groove crank pulley fit? [Re: poorboy] #2944822
07/19/21 01:00 PM
07/19/21 01:00 PM
Cab_Burge Online work
Cab_Burge  Online Work
Me thinks not, no provision for driving the alternator work
All the BB cars with power steering and air conditioning I've seen had four groove pulleys scope
Maybe for a car without power steering with air conditioning shruggywork
Re: What does this 3 groove crank pulley fit? [Re: John_Kunkel] #2944954
07/19/21 08:59 PM
07/19/21 08:59 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: What does this 3 groove crank pulley fit? [Re: MadMopars] #2944956
07/19/21 09:02 PM
07/19/21 09:02 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Is it my eyes or are those top two holes close together which would make it asymmetrical shruggy beer
Re: What does this 3 groove crank pulley fit? [Re: TJP] #2944989
07/19/21 10:33 PM
07/19/21 10:33 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Even taking account the camera angle, they do look closer.
Joe
Re: What does this 3 groove crank pulley fit? [Re: Cab_Burge] #2945012
07/19/21 11:54 PM
07/19/21 11:54 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Nearly all of the small blocks with AC had the 3 bely pulley.
Re: What does this 3 groove crank pulley fit? [Re: poorboy] #2945026
07/20/21 01:10 AM
07/20/21 01:10 AM
i haven't had many SB pulleys, especially with air blush
I faintly remember ,I think, seeing one like that though shruggy
