6.4 BGE block #2622001
02/16/19 03:11 AM
02/16/19 03:11 AM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Is there a difference between a 6.4 BGE truck block and the block in the 6.4 challenger?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: 6.4 BGE block [Re: HOTMOPR] #2622012
02/16/19 04:02 AM
02/16/19 04:02 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Yeah, the BGE block is the same as the Hellcat block, just a generally beefier block. To throw a twist into it, SRT's began using BGE blocks as well in '18, so all 6.4's from '18 on are BGE's, truck or car
Re: 6.4 BGE block [Re: WO23Coronet] #2622019
02/16/19 04:34 AM
02/16/19 04:34 AM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
so the earlier 392 cars are not the bge?
Re: 6.4 BGE block [Re: HOTMOPR] #2622030
02/16/19 08:15 AM
02/16/19 08:15 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
5037471BF 2011-2012 water jacket is slightly different.
5045475AD 2013 2017 same water jacket as the BGE but the lower part of the cylinders are not Siamese.
New BGE part # 68166434AD
https://board.moparts.org/ubbthreads/ubbt...tml#Post2513420
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 6.4 BGE block [Re: ric3xrt] #2622171
02/16/19 03:53 PM
02/16/19 03:53 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
when I look up that number it comes up with a 6.2 hellcat block..
68166434AD
Re: 6.4 BGE block [Re: HOTMOPR] #2622179
02/16/19 04:09 PM
02/16/19 04:09 PM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Re: 6.4 BGE block [Re: HOTMOPR] #2622420
02/17/19 01:58 AM
02/17/19 01:58 AM
Australia
aus370 Offline
aus370  Offline
Australia
68166434AD
Same block , Hellcat has shorter stroke .
Re: 6.4 BGE block [Re: aus370] #2622427
02/17/19 02:15 AM
02/17/19 02:15 AM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Whats the difference between the this and the 6.2 block?
5045475AD
68166434AD
Re: 6.4 BGE block [Re: HOTMOPR] #2622432
02/17/19 02:23 AM
02/17/19 02:23 AM
Oakville, Wa
HOTMOPR Offline OP
HOTMOPR  Offline OP
Oakville, Wa
Re: 6.4 BGE block [Re: HOTMOPR] #2624258
02/21/19 04:09 PM
02/21/19 04:09 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
5045475AD
68166434AD
External Ribbing and internal 68166434AD
Casting # 68249194AA (not part#) is the original Hellcat block and the only block in 2015 that is supposed to have the support ridge between the cylinders at the bottom of the water jacket, starting in 2016 all BGE blocks have that internal ridge and the external support ridges between the bottom of the water jacket and the lower casted part of the block...
2011-2015 SRT Blocks have 6.4 Casted in to them, 2011-2012 Are the 5037471BF part# and NO external support ribs 2014-2016 part #5045475AD have a thicker cylinder wall but NO extremal ribbing.2016/17 seems to be a change over year for the SRT392s, some of the old 6.4 casted block and BGE casted blocks seem to have been used in the SRT 392 cars.
All truck blocks have BGE casted in to them as do the Hellcat/Demon blocks.
......all 6.4s from 2017 to now are the same block, the difference between part #s in 2016 was block color.
Re: 6.4 BGE block [Re: ric3xrt] #2624263
02/21/19 04:17 PM
02/21/19 04:17 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Here's the 2015 Hellcat block with the external ribs
Re: 6.4 BGE block [Re: HOTMOPR] #2624804
02/22/19 05:45 PM
02/22/19 05:45 PM
Texas
0
03heavy Offline
03heavy  Offline
Texas
Check this out
I have a 2014 6.4 from a ram 2500
It does not have bge stamped on the block just 6.4
Painted black and has the “hellcat heads “
And according to the previous post
The block has the extra webbing
I have pictures but can’t upload them
Re: 6.4 BGE block [Re: HOTMOPR] #2624924
02/22/19 11:31 PM
02/22/19 11:31 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
So the early Ram 2500 6.4 BGE blocks didn’t have the external running but still have the beefier bores? Do you have a pic of the internal reinforcement?
Re: 6.4 BGE block [Re: WO23Coronet] #2700059
09/23/19 09:29 AM
09/23/19 09:29 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
BUMP
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
6.4 BGE block [Re: 03heavy] #2944792
07/19/21 11:19 AM
07/19/21 11:19 AM
The NB Vermont
dustaboy74 Offline
dustaboy74  Offline
The NB Vermont
I know this is an old post but I wanted to follow up on this as I bought a year ago a 6.4 short block out of supposedly a flooded 2015 Ram 2500. Based on the year I would expect it to be a BGE block but this block says 6.4 on the side and doesn't match any of the part numbers I can find. It looks like it has the same webbing on the side of the block as the BGE so my question is, is it really a BGE block?
Re: 6.4 BGE block [Re: dustaboy74] #2944800
07/19/21 12:03 PM
07/19/21 12:03 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
I imagine it would have to be, the only other 6.4 was the SRT and those were orange, SRT blocks supposedly were a little "slimmer" as a weight cutting measure.
