Stand alone engine control for VVT engines??? #2936695
06/25/21 01:10 PM
06/25/21 01:10 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
What is the easiest way to stick a junk yard 5.7 or 6.4 VVT engine into an old muscle car? I have one of each and a customer who wants me to stick one in his 72 road runner. Is there a controller and harness that runs a complete drop out engine? If nothing like that is available yet would an MSD hemi 6 control the coils on a VVT engine with a carb or do I need to swap tone rings and lock cam...?
Re: Stand alone engine control for VVT engines??? [Re: HotRodDave] #2936719
06/25/21 03:14 PM
06/25/21 03:14 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
MS3 Pro Evo or Ultimate will do it and still run the VVT. I think they have a plug and play setup also.
Re: Stand alone engine control for VVT engines??? [Re: fbs63] #2936725
06/25/21 03:36 PM
06/25/21 03:36 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Holley Terminator X can control the EFI and VVT. They've got an entire swap kit with harness.
Re: Stand alone engine control for VVT engines??? [Re: MarkZ] #2936885
06/26/21 09:49 AM
06/26/21 09:49 AM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
If you want easiest, get the mopar kit. If the engines are stock they will run like the factory cars as they have stock tunes. Everything else you need to tune yourself or get someone to do it.
87 dakota 6.1 hemi
Re: Stand alone engine control for VVT engines??? [Re: Glen440] #2937503
06/27/21 11:04 PM
06/27/21 11:04 PM
IL
furious70 Offline
furious70  Offline
IL
well, easiest is mopar kit if you have a car engine.
Cheapest is MS3
Holley is a good choice
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Stand alone engine control for VVT engines??? [Re: furious70] #2937609
06/28/21 11:47 AM
06/28/21 11:47 AM
okla.
sam64 Offline
sam64  Offline
okla.
The Holley terminator x takes up a lot of real estate because of how the harness is made where it all connects at the controller. Approx. 16x16 inches for controller and coil drivers and so on. I bought the 2013 up for a 2018 5.7 swap and the knock sensor connecters are for the 2005 style sensors it also has some extra harnesses that it doesn't use Tps and Iac.If I was to do it again on a stock engine I would use the Mopar kit.
Re: Stand alone engine control for VVT engines??? [Re: HotRodDave] #2938251
06/30/21 05:42 AM
06/30/21 05:42 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
You might like to check out Edelbrock aswell !
Re: Stand alone engine control for VVT engines??? [Re: 1Fast340] #2944412
07/17/21 10:10 PM
07/17/21 10:10 PM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
"Use the Mopar kit"....does anybody have info on a kit for a 6.1? All I can find is old Google results for 5.7 and 6.4.
I've been waiting over 2 weeks for a response from Holley regarding their stuff and I'd gladly go with Ma Mopar if that is an option.
2008 Charger SRT8 6.1 into 1970 Barracuda (currently 440)
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: Stand alone engine control for VVT engines??? [Re: Cheeto] #2944426
07/17/21 10:35 PM
07/17/21 10:35 PM
USA
hudsonhornet7x Offline
USA
I only think the Mopar kits are for the newer vvt engines. I personally would use the new pro flow 4 kit from edelbrock. Here is a link. https://www.edelbrock.com/pro-flo-4...-gen-iii-hemi-w-tablet-36150-bundle.html
My buddy Dave works for Comp Cams and he says that this is a really nice kit for the money.
Re: Stand alone engine control for VVT engines??? [Re: HotRodDave] #2944487
07/18/21 09:23 AM
07/18/21 09:23 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Easiest is Holley terminator X
Cheapest is changing the reluctor wheel to an ealier version and run a carb with MSD Hemi 6. ( Don't know why Holley hasn't offered thisfor the 64 tooth as the have it for the LS).
Pick your poison.
Even cheaper way would be to mount a 32 tooth wheel to the Balancer?
Matt
Re: Stand alone engine control for VVT engines??? [Re: MattW] #2944543
07/18/21 12:29 PM
07/18/21 12:29 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Pick your poison.
Matt
64 tooth ?
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Stand alone engine control for VVT engines??? [Re: ric3xrt] #2944548
07/18/21 12:45 PM
07/18/21 12:45 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Stanke VVT plug, it keeps the VVT gear locked with oil Pressure, and doesn't allow it to blead out and let the gear retarded it's self.......which it will with the OEM Solenoid if it's not getting signal.
Re: Stand alone engine control for VVT engines??? [Re: hudsonhornet7x] #2945030
07/20/21 02:58 AM
07/20/21 02:58 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
"The system is SRV calibrated for 4,800 RPM, also not adjustable." ....from the Edelbrock description of the unit. Does this mean it is rev-limited to 4,800 RPM? I tried to search the meaning of "SRV" as related to auto computers but to no avail.
Re: Stand alone engine control for VVT engines??? [Re: RTSrunner] #2945052
07/20/21 07:36 AM
07/20/21 07:36 AM
Glen440 Offline
Glen440  Offline
The SRV is the short runner valve, the active intake manifold. It switches from long to short runners at 4800 rpm. There is no benefit to changing that rpm from a dyno test on engine masters. The Holley terminator x efi you can use whatever rpm you want.
87 dakota 6.1 hemi
Re: Stand alone engine control for VVT engines??? [Re: Glen440] #2945115
07/20/21 11:20 AM
07/20/21 11:20 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
The SRV is the short runner valve, the active intake manifold. It switches from long to short runners at 4800 rpm. There is no benefit to changing that rpm from a dyno test on engine masters. The Holley terminator x efi you can use whatever rpm you want. [/quote]
Ok,that makes sense now,Thanks Glen!
Re: Stand alone engine control for VVT engines??? [Re: ric3xrt] #2945150
07/20/21 12:16 PM
07/20/21 12:16 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Pick your poison.
Matt
64 tooth ?
Reluctor wheel late model is 64 ?
