Dart Cast Iron Gen 3 Hemi Block #2941596
07/09/21 05:29 PM
07/09/21 05:29 PM
Southern Missouri
Wailin D Offline OP
Wailin D  Offline OP
Southern Missouri
It looks like the Dart cast iron Gen 3 Hemi block is available.
PRI quotes:
“This block will change the game,” promised Mike Sanders. “We’ve added extra cooling capacity and changed the oiling system.”
The new block will not allow MDS (cylinder deactivation) but will be available with or without provisions for variable valve timing (VVT). It also comes with steel four-bolt mains in all five locations and will be available in either a 9.250- or 9.285-inch deck. Maximum bore will be 4.250-inch.
“Now you can build nearly a 500-cubic-inch Gen III Hemi,” Sanders noted. —Mike Magda
Re: Dart Cast Iron Gen 3 Hemi Block [Re: Wailin D] #2941607
07/09/21 06:41 PM
07/09/21 06:41 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Glad someone stepped up and made a siamese bore for these but it looks like a step back from the factory 6 bolt mains? Is the material that much better that they are not needed?
Re: Dart Cast Iron Gen 3 Hemi Block [Re: HotRodDave] #2941683
07/09/21 10:31 PM
07/09/21 10:31 PM
USA
hudsonhornet7x Online content
hudsonhornet7x  Online Content
USA
All of the hemi blocks I have messed with were 4 bolt mains. But I could be off base here.
Re: Dart Cast Iron Gen 3 Hemi Block [Re: hudsonhornet7x] #2941698
07/10/21 12:16 AM
07/10/21 12:16 AM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
Gen3 hemi is 4 bolt. Must be confused with a ls.
87 dakota 6.1 hemi
Re: Dart Cast Iron Gen 3 Hemi Block [Re: HotRodDave] #2941723
07/10/21 08:50 AM
07/10/21 08:50 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
You post a lot about building G3s, have you never been into the bottom end of one?
They are all 2 bolt caps with cross bolts
Re: Dart Cast Iron Gen 3 Hemi Block [Re: Glen440] #2941724
07/10/21 08:58 AM
07/10/21 08:58 AM
Katy, TX
Bakaruda Offline
Bakaruda  Offline
Katy, TX
I believe they are referring to the cap bolts not the spade bolts. MMX sells a cap with 4 bolts and 2 spade bolts. Which most refer to as a 6 bolt cap. Maybe I'm wrong but that is what I thnk.
1969 Barracuda GENIII Hemi
2019 Ram 1500 Laramie
Re: Dart Cast Iron Gen 3 Hemi Block [Re: Wailin D] #2941764
07/10/21 11:40 AM
07/10/21 11:40 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Good, maybe this even leads to new intake and cylinder head options as well.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Dart Cast Iron Gen 3 Hemi Block [Re: Wailin D] #2941769
07/10/21 11:54 AM
07/10/21 11:54 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Not sure why he keeps saying "can bore to 4.250" 4.20 is max on the block, a 4.250 bore will leave only .105 between cylinder bores......Not good even for siames blocks....... bottom end of the block is thicker where the Main studs go in no "shelf" tpe casting... still only two in the cap and two cross bolts....the ONLY 6bolt G3 (4 cap ,2 cross) were the Mclaren Alum block for the ill fated 5.0 liter program in 04-06 ...
There are some big advantage with this block
1) it has two extra Head bolts , per cylinder one @ 12 o'clock and one @ 6 o'clock. Like some of the Aftermarket LS blocks........ it's a true 6 head bolts per cylinder can you say 30+lbs of BOOST
2) the Water Jacket it's more like the BGE/Hellcat and less like the Eagle 5.7 and the 5.7/6.1 block.
3) the Lifter oil galleys(passages) connect all 8 on the same bank...the OEM blocks are split in to 4 sections of 4.
4) unlike the BGE block is it a true siamese bore, BGE block has a ridge from the floor of the water jacket up to about an inch in height connecting the cylinders.
the deck is .10 thicker then the 6.1 block @ the 9.25 deck height and .135 thicker then the stock BGE at the 9.285 Height.
Bad news...it's still tight in the crank area for anything over 4.125 stroke....4.08 still needs a little notching for the oil cross passage on the passenger side rear oil drain back and major surgery for the 4.125 and larger stroke.
for the NON-VVT crowd it's basically a BGE version of the old 6.1 block.....Better cooling, thicker deck and cylinder walls that don't move around above 18lbs of Boost. .(it's the Block you Need Dragula for your Eddelbrock heads)
HP wise...BGE's will go 1500 with good caps. and 4.10 max bore, 1300/1400 with 4.125-4.165 before the break...these should go 1800 at least with a good tune and 4.10 bore..not sure how well they'll take a 4.20 bore and BIG boost.
BMP Alum Block is going to drop some time around late October and early December....that will be a real game changer .......I haven't talked to Darren @ KB in a while I know they are close to releasing their block.
Future is looking a little brighter for the G3 crowd.......there will be 4 Alum block options this time next year...now how long will they stay in production.....I don't know.
Next up is a Head that'll flow....VERY well....I mean VERY well...Think AJPE or Frankenstein P48 Hemi well....and true 6 bolt around the cylinder and uses 5.60-5.80 length valves......Not 5.14
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Dart Cast Iron Gen 3 Hemi Block [Re: hudsonhornet7x] #2941794
07/10/21 01:12 PM
07/10/21 01:12 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Your right, I just got done building an aluminum 3.5 V6 that had 6 bolts and had that in mind. I was doing a bunch of research thinking about building it into a 4.0 V6 so that was on my brain. Still seems like it would have been a good idea for a motor that could go past 1000 HP like a new hemi block should be able to go.
Re: Dart Cast Iron Gen 3 Hemi Block [Re: HotRodDave] #2941901
07/10/21 08:15 PM
07/10/21 08:15 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I might have to order one of those, although, I would want to run a 4.25 crank in it if possible.
Re: Dart Cast Iron Gen 3 Hemi Block [Re: Dragula] #2941936
07/10/21 11:04 PM
07/10/21 11:04 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
4.25 crank fits , lots of work, but it fits with the 4.20 Bore and a 4.25 crank puts you@ 471 CI
Re: Dart Cast Iron Gen 3 Hemi Block [Re: ric3xrt] #2941990
07/11/21 10:37 AM
07/11/21 10:37 AM
Dragula Offline
Dragula  Offline
That would be a beast of a G3
Re: Dart Cast Iron Gen 3 Hemi Block [Re: ric3xrt] #2943581
07/15/21 01:58 PM
07/15/21 01:58 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
See the new pushrod Fleet engine by ford?
445 CID
4.220 bore and a 3.9 something stroke.
It looks like a cross between a G3 and LS lol
I know nobody cares but maybe Fiat will respond to this?
But I'm thinking that the current G3 BGE casting would not support a big bore. It would need a total redesign.
Crate engine starts at 7,800.00 IIRC
Re: Dart Cast Iron Gen 3 Hemi Block [Re: MattW] #2943598
07/15/21 03:11 PM
07/15/21 03:11 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
445 CID
The hemi valve arrangement don't need as big a bore as a wedge to flow the same amount of air, they could easily extend the 392 deck a half inch and stroke to 4.0 and bore to 4.125 to get close enough and make it industrial kind of sturdy, make the displacement come out to 426. This taller deck configuration would also allow even longer intake runners for more TQ and with existing BGE heads make plenty of power to compete with the ferd. Small bore long stroke is also a better way to get past emissions.
Re: Dart Cast Iron Gen 3 Hemi Block [Re: MattW] #2943619
07/15/21 05:15 PM
07/15/21 05:15 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
445 CID
Ford pretty much owns the commercial market that engine is used for, shuttle buses, RV's etc. Dodge gave up on that market years ago so I wouldn't expect much from them.
Re: Dart Cast Iron Gen 3 Hemi Block [Re: Wailin D] #2943789
07/16/21 01:16 AM
07/16/21 01:16 AM
I wonder if this is cast grey iron or the better cast ductile iron?
Time to make the call to find out I guess scope
Re: Dart Cast Iron Gen 3 Hemi Block [Re: Cab_Burge] #2944185
07/17/21 09:38 AM
07/17/21 09:38 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Both have their advantages,
Gray dampens vibrations better, machines better, cheaper to manufacture , better thermal conductivity,(transferring combustion heat to water jacket) oddly , its stiffer then ductile, which also means it's brittle compared to Ductile.
Ductile ...has a greater tensile strength, impact and fatigue resistance
High end cylinder sleeves are made from Ductile, while stock or lower end sleeves are gray ... "dry sleeves" are almost always made from gray, a lot of your "wet" sleeves are made from ductile.
The G3 blocks have one of the higher nickel contents in the OEM engine blocks, highest of any Chrysler block made,.
Re: Dart Cast Iron Gen 3 Hemi Block [Re: SRT6776] #2944187
07/17/21 09:41 AM
07/17/21 09:41 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
445 CID
"dodge" was competitive with the Iron V10 but once DCX took over the writing was on the wall ..I'm guessing they felt it was money wasted to pursue that market any longer....I don't agree
Re: Dart Cast Iron Gen 3 Hemi Block [Re: HotRodDave] #2944189
07/17/21 09:44 AM
07/17/21 09:44 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
445 CID
Every .25 inch you raise the deck height of the G3 block it widens the G3 1 inch.....
Re: Dart Cast Iron Gen 3 Hemi Block [Re: ric3xrt] #2944385
07/17/21 08:28 PM
07/17/21 08:28 PM
Home
SRT6776 Offline
SRT6776  Offline
Home
445 CID
Mercedes removed Dodge vans and replaced them with sprinters, at least in the shuttle and RV world.
There are some ram based RV's coming back though, but diesels
