Oil Expander Ring Ends -Orientation Question #2943801
07/16/21 03:37 AM
07/16/21 03:37 AM
California
BigDaddy440 Offline OP
California
Until today, I thought oil expander rings were ALL non-directional.
I noticed a ring manufacturer indicate that on their piston ring set instructions that the oil expander (the bottom wavy ring) is indeed directional. This really surprised me.
The issue is where the ENDS come TOGETHER.
In searching online, I've found two diagrams showing the opposite recommendation of each other.
I know, I know, just follow the directions...
But what is the thought behind this? If you install a compression ring upside down it will push oil towards the combustion chamber, a big goof, but what about the expander ring installed upside down?
Any thoughts or explanations?
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Oil Expander Ring Ends -Orientation Question [Re: BigDaddy440] #2943851
07/16/21 09:45 AM
07/16/21 09:45 AM
maybe the expanders just provide tension to the oil rings & do not affect oil consumption
Re: Oil Expander Ring Ends -Orientation Question [Re: RapidRobert] #2943905
07/16/21 12:23 PM
07/16/21 12:23 PM
Cab_Burge Online work
Cab_Burge  Online Work
It is NOT MAYBE, they only apply pressure to the scraper rings up scope
BUT, if your brand rings instructions say install them with the ends pointing down do it that way up twocents
I've install many different brands of rings in a lot of different motors and I have not seen any instructions like you found on the interweb confused shruggy
I'm sure I've installed them both ways with that type of oil ring spacer with no bad results shruggy
I do make sure the ends do not overlap and or pile on top of each other twocents
Re: Oil Expander Ring Ends -Orientation Question [Re: Cab_Burge] #2943987
07/16/21 03:21 PM
07/16/21 03:21 PM
California
California
I'm with you Cab, never seen this before.
I'm looking at the paper install instructions from Hastings for this basic ring set and it says "Caution: 2mm oil ring install with gap towards top of piston".
I just follow instructions but it makes me wonder how critical this is in reality.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Oil Expander Ring Ends -Orientation Question [Re: BigDaddy440] #2944056
07/16/21 07:31 PM
07/16/21 07:31 PM
Manufacturers are not going to waste their time, money and ink on putting special instructions with their products unless it is needed, badly.
Follow them, I will up twocents
Re: Oil Expander Ring Ends -Orientation Question [Re: Cab_Burge] #2944064
07/16/21 07:42 PM
07/16/21 07:42 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm not so sure. If the tech line keeps getting calls about "do the ends point up or down", the smart manufacturer will choose one or the other, knowing all the while it doesn't make any difference, just to answer the question.
Re: Oil Expander Ring Ends -Orientation Question [Re: 6PakBee] #2944070
07/16/21 08:33 PM
07/16/21 08:33 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
The expanders I've seen do not contact the cylinder wall and are basically symmetrical with no discernible top or bottom except for the ends. I don't see how installing them up vs down would make a difference.
That being said, I've never seen the direction of installation spelled out in any instructions. If it had been, I would follow the manufactures directions.
Re: Oil Expander Ring Ends -Orientation Question [Re: CMcAllister] #2944074
07/16/21 08:46 PM
07/16/21 08:46 PM
California
California
You're right, they're absolutely symmetrical, except for where the ends come together- They form an arrow of sorts. I'm wondering if when traveling in one direction the expander ring functions better / as intended when that arrow shape may begin to separate and form a gap, pushing out. In the opposite direction the end gap closes. That's the only thing I can think of.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Oil Expander Ring Ends -Orientation Question [Re: BigDaddy440] #2945696
07/21/21 04:35 PM
07/21/21 04:35 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
They function the same regardless of orientation, but seen once where the gap in the rail and the tip lined up, and the tip slipped down in an oil drainback groove and stuck.
