Re: Cleaning part after using EvapoRust? [Re: 6PakBee] #2943705
07/15/21 08:28 PM
07/15/21 08:28 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Nah.
Read his posts, when he is not being rude, he is wanting people to buy parts from him.
Re: Cleaning part after using EvapoRust? [Re: 6PakBee] #2943919
07/16/21 01:16 PM
07/16/21 01:16 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
Originally Posted by 6PakBee
Originally Posted by Little Detroit
its even easier when you read the instructions or go to the website and read the instructions there or you could watch an add on TV or online . Its great to help people in need of a talent or skill that you may have ,but to see someone take the time to post a question that any 5th grader could figure out is just plain lazy. there is a reason for elementary school and it wasn't recess.
I'm going to stick up for Little Detroit a bit. When a post starts out with something like "I've been looking for hours and have found nothing on (fill in the blank)......", that question I'll respond to. The poster has put some skin in the game and, for whatever reason, was unsuccessful. But if a question is posed and after 60 seconds with Mr. Google I have the answer.....????
Now there are some topics that are so broad that Mr. Google will overwhelm you with responses. My favorite subject is paint and body questions, here real world experience to me is more important than label directions you could get from a website.
If you are going to be successful in this hobby, you have to be prepared to invest some time and effort. I know all the oldsters on this forum have walked the face of the earth looking for a part or a procedure, it's part of the game.
Really it's just the car version of "give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime".
Not to get in a longer discussion about this, but isn't this exactly what the original poster asked ? He didn't ask for label directions. He asked what we all do.
Re: Cleaning part after using EvapoRust? [Re: Alaskan_TA] #2943935
07/16/21 02:10 PM
07/16/21 02:10 PM
WV
Little Detroit Online content
Little Detroit  Online Content
WV
the problem with you Berry is that you , can't stand the truth , the truth is sometimes harsh , they all want their 15 mins online and feel that they contributed to the hobby . If you want something done right do it your self , the is no harm in failing as a matter of fact it is better to fail and keep trying til you get it right , you then have learned something on your own and accomplished something.Not all things should be handled this way but most can be solved with just a little effort. however in this particular case the man wanted to know how to rinse off evapo rust , like most things manufactured there are msds sheets warning of what to and what not to do.. alsoin this particular case it says rinse with water . It would have taken less effort and time if he would have read instructions and used a "little " common sence.
Re: Cleaning part after using EvapoRust? [Re: Little Detroit] #2944014
07/16/21 04:55 PM
07/16/21 04:55 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Kind of like a guy saying he is going to buy something then ghosts you
Real Men shift for themselves
Re: Cleaning part after using EvapoRust? [Re: 1DGEMAN] #2944049
07/16/21 07:14 PM
07/16/21 07:14 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Quote
But.....
Many of us using this product have obviously just used this to do what it was designed for - removing rust.
So any logical person with any chemistry knowledge knows this basic fact - Exposing raw steel to water causes..... you guessed it, RUST.
So why rinse with water when it can be rinsed away by more logical products?
There is no logic in introducing water to a bare part just cleaned of rust when it was water exposure that caused the problem in the first place. wave
Re: Cleaning part after using EvapoRust? [Re: Alaskan_TA] #2944176
07/17/21 08:44 AM
07/17/21 08:44 AM
WV
WV
I usually don't respond by calling people names ,but I'm going to make an exception this time just for you Berry, your a freak'n MORON. I even capitolized it so you don't overlook it. I know it's difficult for you but try reading the instructions all the way thru. I would never thought i would have to explain how to read instructions to an Adult , but thats whats necessary with those who are challenged by common sence.
Re: Cleaning part after using EvapoRust? [Re: Little Detroit] #2944177
07/17/21 09:16 AM
07/17/21 09:16 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I too have looked for a way of not using water to clean due to the flash rusting issue. I have tried starter fluid to clean the part instead of water and then sprayed it with Rust Block. It seems to work ok.
Re: Cleaning part after using EvapoRust? [Re: Little Detroit] #2944191
07/17/21 09:47 AM
07/17/21 09:47 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
OK, so..... If the instructions said to rinse the part by clutching it tightly to your chest and then jump of a bridge into a river with it to ensure a good rinse, would you follow the instructions or look for a better way? shruggy
Re: Cleaning part after using EvapoRust? [Re: Alaskan_TA] #2944286
07/17/21 01:45 PM
07/17/21 01:45 PM
WV
WV
like i said ,challenged by common sence .
Re: Cleaning part after using EvapoRust? [Re: Little Detroit] #2944287
07/17/21 01:54 PM
07/17/21 01:54 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Quote
I rinse with water then spray with WD-40 to dissipate the water.
When ready to paint, I remove the WD with lacquer thinner.
This works for me.
Other opinions may differ, and that is OK. up
Re: Cleaning part after using EvapoRust? [Re: Alaskan_TA] #2944297
07/17/21 02:15 PM
07/17/21 02:15 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Guys, please, give it a rest. You both have your opinions, they don't agree, please leave it at that. Thanks in advance. beer
Re: Cleaning part after using EvapoRust? [Re: 6PakBee] #2944350
07/17/21 05:24 PM
07/17/21 05:24 PM
md
mopars4ever Offline
mopars4ever  Offline
md
btw , spelled sense
Re: Cleaning part after using EvapoRust? [Re: mopars4ever] #2944373
07/17/21 07:10 PM
07/17/21 07:10 PM
MD
floyd Offline
floyd  Offline
MD
Originally Posted by mopars4ever
btw , spelled sense
You have to admit, that’s a tad ironic. 😂
Re: Cleaning part after using EvapoRust? [Re: floyd] #2944406
07/17/21 09:40 PM
07/17/21 09:40 PM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
Me thinks perhaps I should have responded in one of the older threads after all. laugh2
Cheeto
It's not perfect.
It's not correct.
It's not yours!
