Oil Expander Ring Ends -Orientation Question
#2943801
07/16/21 03:37 AM
07/16/21 03:37 AM
Posts: 712 California
BigDaddy440
California
Until today, I thought oil expander rings were ALL non-directional. I noticed a ring manufacturer indicate that on their piston ring set instructions that the oil expander (the bottom wavy ring) is indeed directional. This really surprised me. The issue is where the ENDS come TOGETHER. In searching online, I've found two diagrams showing the opposite recommendation of each other. I know, I know, just follow the directions... But what is the thought behind this? If you install a compression ring upside down it will push oil towards the combustion chamber, a big goof, but what about the expander ring installed upside down? Any thoughts or explanations?
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
Re: Oil Expander Ring Ends -Orientation Question
[Re: BigDaddy440]
#2943851
07/16/21 09:45 AM
07/16/21 09:45 AM
RapidRobert
maybe the expanders just provide tension to the oil rings & do not affect oil consumption
[Re: RapidRobert]
#2943905
07/16/21 12:23 PM
07/16/21 12:23 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
maybe the expanders just provide tension to the oil rings & do not affect oil consumption It is NOT MAYBE, they only apply pressure to the scraper rings BUT, if your brand rings instructions say install them with the ends pointing down do it that way I've install many different brands of rings in a lot of different motors and I have not seen any instructions like you found on the interweb I'm sure I've installed them both ways with that type of oil ring spacer with no bad results I do make sure the ends do not overlap and or pile on top of each other
[Re: Cab_Burge]
#2943987
07/16/21 03:21 PM
07/16/21 03:21 PM
BigDaddy440
California
I'm with you Cab, never seen this before.
I'm looking at the paper install instructions from Hastings for this basic ring set and it says "Caution: 2mm oil ring install with gap towards top of piston".
I just follow instructions but it makes me wonder how critical this is in reality.
[Re: Cab_Burge]
#2944064
07/16/21 07:42 PM
07/16/21 07:42 PM
Posts: 10,759 North Dakota
6PakBee
North Dakota
Manufacturers are not going to waste their time, money and ink on putting special instructions with their products unless it is needed, badly. Follow them, I will I'm not so sure. If the tech line keeps getting calls about "do the ends point up or down", the smart manufacturer will choose one or the other, knowing all the while it doesn't make any difference, just to answer the question.
[Re: 6PakBee]
#2944070
07/16/21 08:33 PM
07/16/21 08:33 PM
Posts: 11,709 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The expanders I've seen do not contact the cylinder wall and are basically symmetrical with no discernible top or bottom except for the ends. I don't see how installing them up vs down would make a difference.
That being said, I've never seen the direction of installation spelled out in any instructions. If it had been, I would follow the manufactures directions.
[Re: CMcAllister]
#2944074
07/16/21 08:46 PM
07/16/21 08:46 PM
BigDaddy440
California
That being said, I've never seen the direction of installation spelled out in any instructions. If it had been, I would follow the manufactures directions. You're right, they're absolutely symmetrical, except for where the ends come together- They form an arrow of sorts. I'm wondering if when traveling in one direction the expander ring functions better / as intended when that arrow shape may begin to separate and form a gap, pushing out. In the opposite direction the end gap closes. That's the only thing I can think of.
