removing fuel pump 1988 W-100 #2943264
07/14/21 09:57 PM
07/14/21 09:57 PM
sc
tjmarcus1 Offline OP
sc
Is it best to tilt the bed to remove the fuel pump assy?
Re: removing fuel pump 1988 W-100 [Re: tjmarcus1] #2943346
07/15/21 10:07 AM
07/15/21 10:07 AM
N
NITROUSN Offline
NITROUSN  Offline
N
That is not a bad way as long as everything come apart.
Re: removing fuel pump 1988 W-100 [Re: tjmarcus1] #2943377
07/15/21 11:11 AM
07/15/21 11:11 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
I've never swapped one on an '88, but that's how I did the fuel pump on my 2001. If your choices are tilting the bed vs dropping the tank, remove a few bolts and tilt the bed.
Re: removing fuel pump 1988 W-100 [Re: Fat_Mike] #2943558
07/15/21 01:26 PM
07/15/21 01:26 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
keep in mind that the complete fuel pump module IS NOT AVAIL. if you need 1 and if you can find an NOS one, they are 4-500 dollars. used module is 3-400 dollars. if need rebuilt, tristarradiators rebuilds them to like new.good luck and be careful removing the hoses from the nipples on top.
Re: removing fuel pump 1988 W-100 [Re: trw1982] #2944035
07/16/21 06:22 PM
07/16/21 06:22 PM
sc
sc
Thanks guys, I tilted the bed. It worked great.
