Re: Recommend 833 4 Speed Fluid??
[Re: hemibuzz]
#294210
04/20/09 07:45 PM
04/20/09 07:45 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: 340SHORTY]
#294214
04/21/09 07:45 AM
04/21/09 07:45 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
My 65 oe 4 speed nothing but 90 wt gear oil.Still like new.Rocky
Chrysler Firepower
[Re: TOMRR]
#294219
04/21/09 08:50 PM
04/21/09 08:50 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
There are many favorites out there but the one oil to avoid is any gear oil that is GL5 rated.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: Silverbullet2]
#294220
04/21/09 08:52 PM
04/21/09 08:52 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
I've been looking for Pennzoil Synchromesh locally and nobody seems to stock it. I have access to BG synchro shift and it's GL4 rated. Anybody ever tried it?
Just go to any GM dealer and get Synchromesh.
MB
[Re: CJK440]
#294225
04/22/09 10:38 AM
04/22/09 10:38 AM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
Whats wrong with GL-5 Rated 90W???
Somebody correct me if I am understanding this wrong but the GL-5 has an extreme pressure additive package that works great to eliminate friction on high PSI contact like ring and pinion tooth contact. Problem is it also does the same thing when the the points on the inside of the brass rings try to grip the cone of the gears when shifting. You want that brass to lock onto that taper quick and stop that gear as soon as possible.
You are correct sir....
[Re: Cuda340]
#294226
04/22/09 11:03 AM
04/22/09 11:03 AM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I accidently put a GL-5 oil in my trans one time and it wouldnt even go into gear. Put the Pennzoil back in....like butter
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
