Re: Meziere water pump on bb
[Re: 4mopower]
#2942036
07/11/21 02:05 PM
07/11/21 02:05 PM
Posts: 4,291 Morrow, OH
markz528
Morrow, OH
On my 67 Coronet drag car with a 1/4" plate, would not fit either. I ended up with a remote pump.
[Re: jughed]
#2942108
07/11/21 06:08 PM
07/11/21 06:08 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
I had two BB A-body cars with Meziere's mounted on front of the motor, thick motor-plates, big radiators and large twin shrouded fans on the engine side. Basically the same thing with the new car as well.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: 4mopower]
#2942252
07/12/21 08:11 AM
07/12/21 08:11 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
On my cuda the big Meziere pump won't fit. I use the Meziere pump that drops into the stock style water pump housing. I have a big Griffin radiator (2 rows of 1.25" tubes) and an electric fan/shroud combo off of a 2003 dodge viper.
[Re: an8sec70cuda]
#2942262
07/12/21 09:06 AM
07/12/21 09:06 AM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
Used a BB mezierie pump, 3/8 plate, alternator, vacuum pump, behind a Be-Cool radiator and SPAL Fans. My water pump maybe clears the fans by 1/4 inch in the front. Its a lot of stuff in a small space. Figuring out the engine plate forward was probably one of the most time consuming aspects of this project. Making spacers, finding belts/pulleys to make it all work. I don't think i could have used a shroud or any thicker fans i would have had interference. Luckily the water pump snout dropped dead center where the fans met and had most clearance.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: an8sec70cuda]
#2942315
07/12/21 12:19 PM
07/12/21 12:19 PM
Posts: 162 Chicago-area Illinois
4mopower
On my cuda the big Meziere pump won't fit. I use the Meziere pump that drops into the stock style water pump housing. I have a big Griffin radiator (2 rows of 1.25" tubes) and an electric fan/shroud combo off of a 2003 dodge viper. The total mounting depth is less with the O.E. housing and electric pump? The pump from Meziere is 6.8" for 35gpm and 7.25 for 55gpm. I was wanting to use the 35 since I have it but Meziere recommends the 55gpm for high hp street cars. = less room!
[Re: 4mopower]
#2942318
07/12/21 12:34 PM
07/12/21 12:34 PM
an8sec70cuda
On my cuda the big Meziere pump won't fit. I use the Meziere pump that drops into the stock style water pump housing. I have a big Griffin radiator (2 rows of 1.25" tubes) and an electric fan/shroud combo off of a 2003 dodge viper. The total mounting depth is less with the O.E. housing and electric pump? The pump from Meziere is 6.8" for 35gpm and 7.25 for 55gpm. I was wanting to use the 35 since I have it but Meziere recommends the 55gpm for high hp street cars. = less room! I was trying to fit the 55 gpm pump and the measurement I had was bigger than my current setup...it would interfere w/ my electric fan. It is a single fan in the center of the radiator.
[Re: Sammy]
#2942547
07/13/21 08:03 AM
07/13/21 08:03 AM
an8sec70cuda
Put the fan on the grill side of the radiator and make it push. Instead of the engine side. Problem solved. . In my particular application, that won't work. I'd have to use a different fan setup.
[Re: 4mopower]
#2943201
07/14/21 07:18 PM
07/14/21 07:18 PM
HemiDart68
North of Detroit
HemiDart68, your using Spal fans without a shroud to make it fit? Yes sir, two SPAL puller fans. No shroud. Really large Be-Cool radiator, meziere with no restrictor or thermostat. I use Be-Cool coolant on the street. Never hints at overheating.
[Re: HemiDart68]
#2943205
07/14/21 07:25 PM
07/14/21 07:25 PM
HemiDart68
North of Detroit
trying to find a photo, this is the closest i have to showing that view
[Re: 4mopower]
#2943424
07/15/21 12:25 PM
07/15/21 12:25 PM
Posts: 876 Arizona
PolyDart
Arizona
I'll get the radiator ordered and trim the fan housings a bit as PolyDart did, worst case I'll have to get a remote pump.
Thanks guys!
John. Additional detail photos...
[Re: PolyDart]
#2943438
07/15/21 12:37 PM
07/15/21 12:37 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
I have the SD Meziere in an aluminum housing, 2 1" row radiator from Speed Cooling, and AR Engine Plate. It's close, but fits. IMG_2429 by Greg Ault, on Flickr IMG_2430 by Greg Ault, on Flickr
