Re: Repair Options For Rear Plastic Convertible Side Panels
[Re: 69gtxvert]
#2941564
07/09/21 03:23 PM
07/09/21 03:23 PM
Posts: 892 MA
steve70
MA
I's probably ABS. If you wipe a little acetone on the back of the panel and you get plastic on the rag that will confirm if it's a butyl type of plastic. If it is you can use regular ABS cement or even acetone and a reinforcing strip of ABS plastic on the back side.
1970 Challenger T/A 4 speed
[Re: 69gtxvert]
#2944957
07/19/21 09:03 PM
07/19/21 09:03 PM
Posts: 7,542 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I have a couple of cracks and one small piece broken off an interior rear side panel in my '69 convertible and am looking for experiences and opinions on how to repair without actually making the damage worse. How structurally strong does the repair have to be? In case this is useful: I had a '67 side panel with a hairline crack from the lower edge near it's mounting bracket, extending up about 4inches. One of those situations where the crack would disappear if I just pushed the sides together. I'd say it was Medium structural. Anyway, I used Super Glue - cyanoacrylate. I applied the liquid to the back, and let the glue weep into the hairline crack, and it set up nice. Not visible from the front. But you gotta be careful if it oozes to the front surface, because wiping it will leave a streak. Let us know what type of plastic you find, I swear mine has fibers embedded in it, but it's def not traditional epoxy resin fiberglass. I think Mopar put fibers it the plastic to control shrinking and cracks. - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: steve70]
#2944963
07/19/21 09:15 PM
07/19/21 09:15 PM
Posts: 21,840 Kirkland, Washington
Pacnorthcuda
I's probably ABS. If you wipe a little acetone on the back of the panel and you get plastic on the rag that will confirm if it's a butyl type of plastic. If it is you can use regular ABS cement or even acetone and a reinforcing strip of ABS plastic on the back side. This…….
