Re: Rear main oil leak
[Re: fastmark]
#2941090
07/08/21 09:14 AM
07/08/21 09:14 AM
Posts: 10,021 MN
JERICOGTX
MN
After years of never having a leak, I was talked into a billet retainer, and new style seal. Leaked horribly from the get go. Took it out, installed a FelPro Viton seal, and the stock retainer, and the leak was gone.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2941096
07/08/21 09:45 AM
07/08/21 09:45 AM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
After years of never having a leak, I was talked into a billet retainer, and new style seal. Leaked horribly from the get go. Took it out, installed a FelPro Viton seal, and the stock retainer, and the leak was gone. What he said...I have also had good luck with the Superformance rear main seals..
[Re: Al_Alguire]
#2941217
07/08/21 02:48 PM
07/08/21 02:48 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Although I'm not certain what brand Superformance uses, they are probably the same Viton rear seal that the Fel-Pro is... they are all sourced from major "seal" manufacturers. Changing the retainer is most helpful.... regardless of the seal source.
I'm a former long-time aftermarket engineer from Fel-Pro.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: JERICOGTX]
#2941240
07/08/21 03:45 PM
07/08/21 03:45 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
After years of never having a leak, I was talked into a billet retainer, and new style seal. Leaked horribly from the get go. Took it out, installed a FelPro Viton seal, and the stock retainer, and the leak was gone. THIS x10!!!!!
"Any fool can know. The point is to understand"
- A. Einstein
[Re: EvilB1Dart]
#2941302
07/08/21 05:51 PM
07/08/21 05:51 PM
Posts: 16,474 On the run…
BloFish
On the run…
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/2815954/Searchpage/1/Main/232394/Words/%2BRear+%2Bmain/Search/true/billet-rear-main-seal-retainer.html#Post2815954
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: Mopar Mitch]
#2941377
07/08/21 09:38 PM
07/08/21 09:38 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
I'm a former long-time aftermarket engineer from Fel-Pro. but I'm not a long time gasket engineer I buy those seals by the dozens so I don't run out on the weekend or at night, no leaks in a longtime on both knurled or smooth cranks
