I was told by a older Powermaster tech to use a #4 gauge wire from their 100 amp single wire alternator to the cut off switch in the trunk on my S/P bracket car with two 850 CCA marine deep cycle batteries mounted in the trunk on my 1970 Cuda. That was several years ago
![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
I call them again earlier this year and talk to a different younger tech rep on using one of their 150 amp single wire alternator for a similar car(1969 Roadrunner) with two 1000 CCA deep cycle marine batteries, he suggested using either #10, #8 and or #6 copper wire, I used the #8 and grounded the alternator on its grounding lug with a short piece of #4 copper to a threaded hole in the cylinder head near the alternator
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
I haven't ran that car yet so I'm not sure if I chose the correct wire size or not
![work work](/ubbthreads/images/graemlins/custom/work.gif)
I'll check it for heat after a run at the batteries at the races
![luck luck](/ubbthreads/images/graemlins/custom/luck.gif)
I use a 100 amp stock alternator in my old pump gas Duster, I bypassed the amp meter with a piece of #10 gauge wire and ran a #10 wire from the alternator to the battery cable on the starter solenoid on the firewall and added a Voltmeter that worked only with the key on in the run position so it wouldn't drain the battery with the battery cut off switch left on
![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif)
