Rear main oil leak #2941088
07/08/21 09:11 AM
07/08/21 09:11 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Ok I’ve tried two of those Mancini billet seals on my last two biulds. Both came in as leakers. One Still leaks but the other is sealed fine. My guy that does my machine works has a 440 builds that has been through several seals with the stock retainer and they still leak. These things are hit or miss seams like on B.B. Mopar. My question is will the factory rope seal work better and can you still get them? I remember always having oil leaks back in the day and it was just something you lived with.
Re: Rear main oil leak [Re: fastmark] #2941090
07/08/21 09:14 AM
07/08/21 09:14 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
After years of never having a leak, I was talked into a billet retainer, and new style seal. Leaked horribly from the get go. Took it out, installed a FelPro Viton seal, and the stock retainer, and the leak was gone.
69 GTX 68 Road Runner
Re: Rear main oil leak [Re: JERICOGTX] #2941096
07/08/21 09:45 AM
07/08/21 09:45 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What he said...I have also had good luck with the Superformance rear main seals..
Re: Rear main oil leak [Re: Al_Alguire] #2941217
07/08/21 02:48 PM
07/08/21 02:48 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Although I'm not certain what brand Superformance uses, they are probably the same Viton rear seal that the Fel-Pro is... they are all sourced from major "seal" manufacturers. Changing the retainer is most helpful.... regardless of the seal source.
I'm a former long-time aftermarket engineer from Fel-Pro.
Re: Rear main oil leak [Re: Mopar Mitch] #2941224
07/08/21 03:03 PM
07/08/21 03:03 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
all of my "rear main/pan" leaks were from something else. it's time consuming but be patient and look for other sources of the leak before tearing into the seal.
Re: Rear main oil leak [Re: JERICOGTX] #2941240
07/08/21 03:45 PM
07/08/21 03:45 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
THIS x10!!!!!
"Any fool can know. The point is to understand"
- A. Einstein
Re: Rear main oil leak [Re: EvilB1Dart] #2941302
07/08/21 05:51 PM
07/08/21 05:51 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/2815954/Searchpage/1/Main/232394/Words/%2BRear+%2Bmain/Search/true/billet-rear-main-seal-retainer.html#Post2815954
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Rear main oil leak [Re: Mopar Mitch] #2941377
07/08/21 09:38 PM
07/08/21 09:38 PM
iagree but I'm not a long time gasket engineer shruggy
I buy those seals by the dozens so I don't run out on the weekend or at night, no leaks in a longtime on both knurled or smooth cranks up
Re: Rear main oil leak [Re: Cab_Burge] #2941399
07/08/21 11:01 PM
07/08/21 11:01 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I got three of them Billet retainer. Two of them in use. work well for me. One of them has got O-ring on the side it is junk don't like it at all. I always use them FelPro Viton seals..
Re: Rear main oil leak [Re: VernMotor] #2941548
07/09/21 02:48 PM
07/09/21 02:48 PM
moparx Online content
moparx  Online Content
i'm not an engine builder, but from years of reading about rear main leaks on big blocks, having the retainer bolt holes drilled a touch oversize may allow the retainer to seat the seal to the crank better without the bolts "pulling" the retainer to one side or the other, causing a leak ?
or am i missing something ? shruggy
i'm looking closely at this because my charger and panel truck are both big block powered.
beer
Re: Rear main oil leak [Re: moparx] #2941632
07/09/21 07:20 PM
07/09/21 07:20 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I followed Monti's direction on installing that rear main seal. I used the billet seal retainer and Superformance seal clocked at 12 oclock and 6 oclock on the parting lines. no leaks the first 2 seasons, then the leak started and hasn't stopped. I just live with it.
