65 Cuda, 273HP #2940591
07/06/21 06:06 PM
07/06/21 06:06 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
My friends 65 Cuda has a vacum canister about the size of a loaf of bread mounted on the inner fender, is this to help the dual point distributor. It's a 4speed car too if that helps.
Re: 65 Cuda, 273HP [Re: MO_PA] #2940596
07/06/21 06:13 PM
07/06/21 06:13 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
That’s a back up to the power brake reservoir, it’s a power brake car right?
Re: 65 Cuda, 273HP [Re: Pacnorthcuda] #2940598
07/06/21 06:17 PM
07/06/21 06:17 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
I'm not sure if it has power brakes.I'll call my pal and report back here.
Should there be a check valve?
Re: 65 Cuda, 273HP [Re: MO_PA] #2940614
07/06/21 06:58 PM
07/06/21 06:58 PM
Yes, there would be a check valve
