Size fittings that go on brake proportion valve? #2939269
07/03/21 10:49 AM
07/03/21 10:49 AM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
Working on 70 cuda. Replacing all lines (will make my own) on the brakes
The line is 3/16 but what size is the fittings? And one is a larger size...7 one size 1 a larger size
...even betters if someone had a link to buy all 8 fittings. Also the 2 that go on the master fly
Thanks in advance
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Size fittings that go on brake proportion valve? [Re: toplescuda] #2939438
07/03/21 02:56 PM
07/03/21 02:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The factory brake lines use an inverted flare fitting. The flare nut is the part that goes on the line behind the flare and threads into the fitting, they are usually 3/16" and 1/4"...your local auto supply will have them. The MC flare nuts have larger threads, 1/2" and 9/16".
