Page 1 of 3 1 2 3
904 race trans #2938984
07/02/21 11:12 AM
07/02/21 11:12 AM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
What are you using in your trans other than the normal parts? Does it hold up? Mine Will be behind a 340. Don’t need a pro trans. Thanks
Re: 904 race trans [Re: cudaman1969] #2939008
07/02/21 12:37 PM
07/02/21 12:37 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I just used the typical upgrade parts when I built mine a few years ago. RMVB, Alto Red Eagle racing clutches, Kolene steels, thicker band strut, red lined bands, teflon rings and rear billet servo. I did upgrade to an oem 5 disc drum and Multi-Spring Pack with Billet Retainer.
No issues but my car is lite 2513 lbs.
Re: 904 race trans [Re: RTSE4ME] #2939044
07/02/21 02:36 PM
07/02/21 02:36 PM
fredericksburg,va
fredericksburg,va
What kind of HP
Re: 904 race trans [Re: cudaman1969] #2939045
07/02/21 02:42 PM
07/02/21 02:42 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Car runs high 9s @133 so far so whatever hp that is..
Re: 904 race trans [Re: RTSE4ME] #2939052
07/02/21 03:18 PM
07/02/21 03:18 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Jay is running low 9’s with his 904
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 904 race trans [Re: pittsburghracer] #2939053
07/02/21 03:23 PM
07/02/21 03:23 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Mine runs mid tens at 3600lbs. Its got A&A red clutches, A&A spring pack, and a TA reverse valve body.
68 Barracuda Formula S 340
Re: 904 race trans [Re: Bad340fish] #2939055
07/02/21 03:27 PM
07/02/21 03:27 PM
fredericksburg,va
fredericksburg,va
How often are they checked or inspected?
Re: 904 race trans [Re: cudaman1969] #2939058
07/02/21 03:38 PM
07/02/21 03:38 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't have a lot of data with mine. I maybe put 40 or so passes and drag week(got it really hot once) on it in 2018. I tore it apart in 2019 and looked at it and it looked great. It just had stock clutches and steels in it so I changed it to the red clutches and kolene steels because I wasn't super pleased with the 2-3 shift and the upgrade took care of that. I will probably not inspect it again until I have an issue I feel needs attention.
I ran my 727 for close to 15 years on the same fluid and it still worked amazingly well. I made the move to 904 knowing I would go faster and maybe have to look it every season or two.
Re: 904 race trans [Re: Bad340fish] #2939074
07/02/21 04:50 PM
07/02/21 04:50 PM
fredericksburg,va
fredericksburg,va
Same here with the 727, never had a 904 though, real world info from you guys
Re: 904 race trans [Re: cudaman1969] #2939162
07/02/21 09:35 PM
07/02/21 09:35 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I have a great 904 for a 400hp small block.... DON’T TRY THIS AT HOME! laugh2 I have 67 passes on my 904 off the trans brake at 4K converter flash to 6100. We go 1.21 to 1.25 60ft on good tracks, and have been running 9 teens/.20s. ALL stock components with the exception of the A&A front spring pack, A500 flat drive gears in the pump, and front band. Both clutch drums have been cross drilled for fluid relief. I talked with Darren at Pro Trans and he was like... “I’d run it!” laugh2 I’m hoping to do some major upgrades to it over our ultra short winter break.
It’s a shame.... with the 727, small 598 intake, and 4150 carb it was a really consistent 9.5/.6 bracket machine! Sold the 727 and now I have to find homes for the converters smile
Car weighs 2970 race ready....
“I don’t need a Pro Trans”..... EVERYBODY needs a Pro Trans!! laugh2
Re: 904 race trans [Re: J_BODY] #2939194
07/02/21 11:23 PM
07/02/21 11:23 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Multi spring pack. Blue Plates and Kolene. Rollerize the output shaft support if you are going to be spinning any RPMs (or even if you aren't). Convert to the late model converter hub and pump with the flats, As much billet as you can afford. Servos, drums,
Re: 904 race trans [Re: CMcAllister] #2939238
07/03/21 08:39 AM
07/03/21 08:39 AM
fredericksburg,va
fredericksburg,va
Thanks for all the input from everybody. Class-bracket-fun car, maybe high tens. 3190 to 3310 pounds A-body
Re: 904 race trans [Re: cudaman1969] #2939246
07/03/21 09:11 AM
07/03/21 09:11 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
The issue I had trying to run a 904, had nothing to do with the clutches, or bands. The issue I had was breaking the case where the low reverse roller clutch attaches. If you are going to run a 904, my advice is to get the best low reverse bolt in roller clutch available, and make sure you have a blow proof drum up front. I busted my 904 many years ago on the street with a 340 six pack. 904's can blow up just like 727's same power flow just smaller lighter parts.
Re: 904 race trans [Re: jwb123] #2939255
07/03/21 09:41 AM
07/03/21 09:41 AM
A727Tflite Offline
A727Tflite  Offline
What adapter are you guys using to bolt it to a big block?
Re: 904 race trans [Re: jwb123] #2939261
07/03/21 10:23 AM
07/03/21 10:23 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
http://tcsproducts.com/media/uploads/user-files/Drum_Tests_Jan_2017.pdf
Failure to 904 drum “possible” but I’m betting the rpms required to achieve this phenomenon are up there with the aftermarket 727 parts due to its smaller size basically putting it above a threshold that we’d seldom see. In my conversations with a couple of shops that have been in the game awhile neither have encountered this happening to a 904.
Re: 904 race trans [Re: A727Tflite] #2939262
07/03/21 10:28 AM
07/03/21 10:28 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I’ve never seen/heard of an “adapter”.... just the pro-flight internals in a 727 case. On my friends the front band adjuster is relocated (welded) so it’s not a total “bolt in” deal. Not sure what else is required as far as machine work. We just flew through it quick to inspect after a broken gear.
Re: 904 race trans [Re: cudaman1969] #2939296
07/03/21 11:55 AM
07/03/21 11:55 AM
PA
moparacer Offline
moparacer  Offline
PA
I had one I built in a mid to high 10 second car that was basically a stock 4 disc 904 with a run of the mill kit, valve body and kickdown lever that was in the car for years with no problems.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: 904 race trans [Re: moparacer] #2939338
07/03/21 12:48 PM
07/03/21 12:48 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Been running 904s for over 30 years only broke one and that was my fault due to a shifter adjustment gone wrong.. Good parts, Turbo Action manual reverse pattern valve body, 5 disc clutch , rollerized output shaft, etc. go thru it about every 5 years or so, I have two identical 904s one in car , one spare... 3150 lb. w/ driver 68 Dart 11.50s on a stop but capable of 10.60s
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: 904 race trans [Re: 11secdart] #2939441
07/03/21 03:01 PM
07/03/21 03:01 PM
fredericksburg,va
fredericksburg,va
Well from what I’ve read so far is that front spring thing should be the first to buy, the rest added down the road as the $$$ comes along.
Re: 904 race trans [Re: cudaman1969] #2939448
07/03/21 03:06 PM
07/03/21 03:06 PM
PA.
"Little"John
"Little"John
PA.
What moved me away from 904’s many many years ago was the weak converter hub issues. It’s the only thing I ever hurt back then. I moved on to running 727’s and never looked back. And now everything I race has a powerglide and I couldn’t be happier as it’s nice having a SAFE aftermarket case.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Page 1 of 3 1 2 3
