Re: Richmond 5-spd vs 6-spd ROD
[Re: AndyF]
#2939997
07/04/21 10:46 PM
07/04/21 10:46 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have a Richmond 5-speed that shifted hard but I always thought it was the Street-twin clutch . I pulled it and took the gears to Liberty's and had them faceplated now it shifts like butter at 6500 RPM. I have done the mods outlined in the link Andy mentioned to few Richmond transmissions and it makes a big difference in the shifting. The good lube like Penzoil Syncromesh oil works well too and stay away from synthetic lube because it doesn't let the syncro rings "grab" the cones on the gears. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: cudaman1969]
#2940188
07/05/21 03:47 PM
07/05/21 03:47 PM
fourgearsavoy
Rittman Ohio
I don’t have too much info on a friends Nash in a street-race 68 Camero (1970s) , 331 cu in modified production engine from Rhere & Morrison. Very high RPM engine, never really knew how fast because he bagged all the time looking for suckers money. 6.50s in the eight at will. Point is he never had a problem power shifting that trans in the 7500-8500 or more range. Can’t think of R&M drivers name right now who did the heads. If it was an early Doug Nash box shifting that high RPM there were no syncros in it . I'm not sure when they came out with the "street" 4+1 syncronized deal but I'm pretty sure it came along in the mid 80's Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: fourgearsavoy]
#2940211
07/05/21 05:08 PM
07/05/21 05:08 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I have a richmond/Nash 5 speed in my 442 with 2.75 rear gears. WIth the deep 1st gear, it works out very nice. I never wished it had another gear. It is kind of a clunky shifting thing, though.
The 6 speed in my hot rod is a t56 magnum 6 speed with 2 overdrives. The big cammed Hemi dosen't like to cruise under 2300 rpm. With 30" tires and 4.57 rear gears, I can't get it into 6th until 70 mph. 5 gears would be enuff.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: fourgearsavoy]
#2940262
07/05/21 08:13 PM
07/05/21 08:13 PM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
I don’t have too much info on a friends Nash in a street-race 68 Camero (1970s) , 331 cu in modified production engine from Rhere & Morrison. Very high RPM engine, never really knew how fast because he bagged all the time looking for suckers money. 6.50s in the eight at will. Point is he never had a problem power shifting that trans in the 7500-8500 or more range. Can’t think of R&M drivers name right now who did the heads (Lee Shepard). If it was an early Doug Nash box shifting that high RPM there were no syncros in it . I'm not sure when they came out with the "street" 4+1 syncronized deal but I'm pretty sure it came along in the mid 80's Gus Never rode with him so you could be right. He could drive a guys F/modified real good
[Re: AndyF]
#2940328
07/05/21 11:43 PM
07/05/21 11:43 PM
Posts: 4,457 Washington
madscientist
Washington
I watched the video. His explanation of gear weight may have some relevance but I doubt it.
It is RPM and clutch disc weight and the number of teeth on the syncro and gear that make them not shift at rpm. You can easily remedy this by slick shifting the sliders, gears and syncros. Then reassemble the box with all the parts.
It will shift smooth and clean at whatever RPM you have the balls for.
[Re: hemienvy]
#2941130
07/08/21 10:29 AM
07/08/21 10:29 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I'm interested in shift quality
I have driven many 833's. With every clutch you can think of. Slick shifted too. It's removing every 2nd tooth on speed gear. Slick shifted opens shift quality and high rpm needs but that is IT. Slow shifting around town is not happening. No overdrive and has external linkage. TKO500's are like old truck transmissions. They got a bit of respect in the hot rod world due to their torque ratings but reading your request AND all the replies. The answer is T56. AndyF mentions it will go in when it's ready. A T56 is always ready. It literally feels like there is nothing to wait for. It slips into every gear no matter how slow or fast you pull the shifter. No matter how slow you pull it in gear, once it's in the gate it almost falls in. Even neutral to first, instantly stops the input shaft and it falls in. These are things NO formulas or bullet point advertising can tell you. The only video I have to demonstrate my opinion was right after we installed the trans. I still was looking for higher/sooner disc release and we still had a super tall rear gear, 3.27. I was also a little shy on the 1 to 2 since the tires spin a bit. https://youtu.be/OmY__bhaR20https://youtu.be/KzTdXe9GU5g
[Re: Magnum]
#2941174
07/08/21 12:07 PM
07/08/21 12:07 PM
madscientist
Washington
I have driven many 833's. With every clutch you can think of. Slick shifted too. It's removing every 2nd tooth on speed gear. Slick shifted opens shift quality and high rpm needs but that is IT. Slow shifting around town is not happening. No overdrive and has external linkage. TKO500's are like old truck transmissions. They got a bit of respect in the hot rod world due to their torque ratings but reading your request AND all the replies. The answer is T56. AndyF mentions it will go in when it's ready. A T56 is always ready. It literally feels like there is nothing to wait for. It slips into every gear no matter how slow or fast you pull the shifter. No matter how slow you pull it in gear, once it's in the gate it almost falls in. Every neutral to first, instantly stops the input shaft and it falls in. These are things NO formulas or bullet point advertising can tell you. The only video I have to demonstrate my opinion was right after we installed the trans. I still was looking for higher/sooner disc release and we still had a super tall rear gear, 3.27. I was also a little shy on the 1 to 2 since the tires spin a bit. https://youtu.be/OmY__bhaR20https://youtu.be/KzTdXe9GU5g I drive my slick shifted box everywhere. You just grind every other tooth off the syncros and put it back together with the struts and springs and send it.
[Re: hemienvy]
#2941406
07/08/21 11:57 PM
07/08/21 11:57 PM
madscientist
Washington
MadScientist, Are you grinding just the synchro, or also the slider and the gear ? How high an RPM can you shift ? Syncro, slider and gears. I just don’t do first gear because there is no need to do that gear. So it saves some time behind the grinder. Then you just assemble the box like a stocker with the struts and springs and send it. In a pinch I had to use my street box in my race car and I didn’t have time to pull the syncros and struts. So I bolted it in. I was shifting at 8500 with a Soft Lock clutch.
[Re: madscientist]
#2953084
08/12/21 10:36 AM
08/12/21 10:36 AM
Magnum
I am not against slick shifting because of some advice from a grandpa. I tried it twice and did not like it for normal driving. It does make an 833 easy to shift fast but I found slow shifting was not smooth or quiet.
Post a video of slow shifting your slick shift. It was 30 years ago. My memory is not clear.
[Re: Magnum]
#2953098
08/12/21 11:20 AM
08/12/21 11:20 AM
madscientist
Washington
Post a video of slow shifting your slick shift. It was 30 years ago. My memory is not clear. Did you leave the syncros, dogs and springs in when you did it? You do that and they will shift like any other box with syncros.
[Re: madscientist]
#2956142
08/21/21 10:07 PM
08/21/21 10:07 PM
Magnum
It was over 25 years ago. Do not remember the details but I think the instructions came from the DC manual.
Any vid of slow shifting a slick shift?
[Re: Magnum]
#2956212
08/22/21 09:08 AM
08/22/21 09:08 AM
madscientist
Washington
Any vid of slow shifting a slick shift? No video, but my wife drives the car. If you did it by the DC book they tell you to leave the syncros, dogs and springs out. You can do that if it’s a dedicated drag car. If you want to drive it like normal on the street, you grind every other tooth off the syncro just like you do the gears and put it all back together like it is stock. It will shift like it did stock, only cleaner and smoother because the syncros are still in there. And, I never ever take any teeth off of first gear or the first gear side of the 1-2 slider or the first gear syncro. That’s just more work and it doesn’t need to be done.
[Re: hemienvy]
#2956213
08/22/21 09:12 AM
08/22/21 09:12 AM
madscientist
Washington
I would like to be able to shift from 1-2, from 2-3, and maybe from 3-4 at 7000~~7200 RPM, I want to keep the synchros and don't mind a slightly slower shift, but I'm not sure if these Richmond trannys like the RPM to shift. My goals to achieve this would include "perfect" bellhousing alignment and clutch adjustment. And, evidently, not using a synthetic fluid. As I just posted, you can slick shift the Richmond just like a Chrysler box. They don’t like to shift at higher RPM’s due to clutch disc weight and too many teeth on the gears, sliders and syncros. So slick shift it like a Chrysler box and do the 2,3 and 4 syncros too. Then put it back together like it’s stock and drive it.
[Re: hemienvy]
#2956395
08/22/21 06:27 PM
08/22/21 06:27 PM
fourgearsavoy
Rittman Ohio
Too bad they don't make slider components with, say, 1.5 times the tooth spacing but 1.5 times bigger teeth. They do when you install Liberty's Pro-shifted gears and sliders, but if I were doing that I would just have the gears Face-plated instead because they last a lot longer and shift like lightning ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
