Is this enough pump for carb and nitrous? #293836
04/20/09 01:00 PM
04/20/09 01:00 PM
Bristol, Va
fasteddie Offline OP
Bristol, Va
Holley Blue with the regulator that comes with it.
-8 line from cell through cannister filter and pump up to regulator. One side feeds carb. Other side feeds nitrous solenoid.
Jets sized for a 250 shot (forget the actual jet #)
I usually just use it at the stripe to bump around if needed, and the occasional full pass at street night.
Trying to decide if I should make the move to a dedicated fuel system.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Is this enough pump for carb and nitrous? [Re: fasteddie] #293837
04/20/09 01:51 PM
04/20/09 01:51 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
get a dedicated system
i guarentee you at a 250 shot and your motor on one holley blue will get you a holed piston
WAXER
Re: Is this enough pump for carb and nitrous? [Re: QWK_ENUF] #293838
04/20/09 02:13 PM
04/20/09 02:13 PM
Bristol, Va
Bristol, Va
OK you talked me into it.
I'm thinking a nitrous enrichment cell up front into another Holley Blue & dead head(already have).
Re: Is this enough pump for carb and nitrous? [Re: fasteddie] #293839
04/20/09 06:05 PM
04/20/09 06:05 PM
Mountain City, TN
JesseR Offline
JesseR  Offline
Mountain City, TN
I run two blues on my truck one for motor, one for nitrous, i ran both off of one pump when i used smaller HP levels, but started having issues with anything more than a 150 HP tune. On our duster we just run one big pump for both. Not trying to change the subject, but i should know you being your from Bristol, do you have any pics of your car? I don't race bristol much, but i sure i've probably seen your car there, Jesse
82' dodge pickup with a 499 low deck
