Why are Braille Lithium 16 volt Batteries... #2937792
06/28/21 07:39 PM
06/28/21 07:39 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
So much better than the rest of the competition?
I know only less than a handful on here use one but wondering what makes them so much better?
What would 2nd in line battery be?
Re: Why are Vraille Lithium 16 volt Batteries... [Re: Sammy] #2937904
06/29/21 08:42 AM
06/29/21 08:42 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I have been using a GoLithium for a little over a year now. So far no issues at all. Whatever one you get, make sure to charge it once a month as they do not like going low
....BAD A$$ STREET CAR.....
Re: Why are Vraille Lithium 16 volt Batteries... [Re: n20mstr] #2937923
06/29/21 09:58 AM
06/29/21 09:58 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Is yours the new updated version with the bigger lugs?
They also raised their price considerably.
Most say 1 Braille is still better than 2 Go Lithiums.
Maybe newer ones are better now.
Re: Why are Vraille Lithium 16 volt Batteries... [Re: Sammy] #2937978
06/29/21 12:26 PM
06/29/21 12:26 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We have run Go Lithiums for a few years. Never had an issue and use them in two cars. One is the older battery the other is the new one. We use a single Go Litium in each car as well. Both have plenty of compression. I have also use Lithium Pros in the Stratus.
Re: Why are Vraille Lithium 16 volt Batteries... [Re: Al_Alguire] #2937980
06/29/21 12:34 PM
06/29/21 12:34 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I've been using the Snyder Motorsports battery(s) with very good results...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Why are Vraille Lithium 16 volt Batteries... [Re: Sammy] #2937982
06/29/21 12:36 PM
06/29/21 12:36 PM
N
n20mstr Offline
n20mstr  Offline
N
I Have the newer version with the larger lugs. I have holley ECU with coil on plug, elec water pump/fan, nitrous and fuel sol, magnaflow fuel pump. electric shifter. Data logger shows maybe 1-1.7 volt drop during a run. (no alternator, you can run an alternator with GoLithium)
Yes i only run one battery also. THe key i think is to make sure your wiring is "corrrect" i checked voltage drop at all my stuff and fixed some wiring , not only did i fix voltage drops but i actually re sized some wires and dropped some weight off the car. Benefit to lithium battery is you can mount in car and get rid of those long wires to the trunk area. But my car is a heads up car and i am concerned with weight and weight distribution, so its nice to be able to put the battery where i want it. Its going behind the front bumper now.
Re: Why are Vraille Lithium 16 volt Batteries... [Re: n20mstr] #2938186
06/29/21 09:22 PM
06/29/21 09:22 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Do you think a Braille charger would work on a Go Lithium 16 volt battery?
I have 2 chargers and need another 16 volt Lithium battery. You can't go wrong with Go Lithiums price and the new generation battery with the bigger lugs looks enticing
Re: Why are Vraille Lithium 16 volt Batteries... [Re: Sammy] #2938310
06/30/21 11:43 AM
06/30/21 11:43 AM
Georgia
66coronet Offline
66coronet  Offline
Georgia
I have two questions on the lithium batteries.
1. Are you running the 12v or the 16v?
2. If you run the 16v, do you use any kind of step down device for the rest of your electrical components?
Re: Why are Vraille Lithium 16 volt Batteries... [Re: Sammy] #2938313
06/30/21 11:50 AM
06/30/21 11:50 AM
N
n20mstr Offline
n20mstr  Offline
N
I dont know if that would work. Call Go Lithium they are pretty good to talk to , and answered a lot of my questions
Re: Why are Vraille Lithium 16 volt Batteries... [Re: 66coronet] #2938315
06/30/21 11:53 AM
06/30/21 11:53 AM
N
n20mstr Offline
n20mstr  Offline
N
16V and no step down devices., Im NOT street driving this car. Except for my lights, i checked everything in my car and the manf all said it would work with 16V. So if you questioning a certain part, call or look on the manf website to see what it says about 16v compatability
Re: Why are Vraille Lithium 16 volt Batteries... [Re: 66coronet] #2938319
06/30/21 12:05 PM
06/30/21 12:05 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Yes 16 volt step-down on my accumulator green solenoid valve and step-down on my Racepak O2 AF/4 Controllers. If you dont, you will fry the controllers and solenoid almost immediately.
Re: Why are Vraille Lithium 16 volt Batteries... [Re: Sammy] #2938373
06/30/21 02:51 PM
06/30/21 02:51 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Just in case anybody needs a step down. MSD brand new, still in the box $50. Summit gets $170 for there's.
[Linked Image][Linked Image]
Re: Why are Vraille Lithium 16 volt Batteries... [Re: n20mstr] #2938774
07/01/21 03:16 PM
07/01/21 03:16 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I called and someone on tech didn't really know so he asked another guy and they said it won't work. Braille battery charging rate is higher than the Go Lithium.
Not sure if they are just trying to cover their butts and just want to seel the separate charger.
I would like to try one again at that price but I had no luck with the 1st run of them when they 1st came out.
Re: Why are Vraille Lithium 16 volt Batteries... [Re: Sammy] #2939241
07/03/21 08:49 AM
07/03/21 08:49 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
There is a safer lithium battery in development right now. The trouble has always been dendrites growing from cathode to anode, shorting it out, and causing a fire, or explosion. There is a glass type material, that promises to block all contact, but still allow interpolation.
I have a braile in one car, and 2 go lithiums in another. Both have served me well, I just always have this nagging feeling about them.
Re: Why are Vraille Lithium 16 volt Batteries... [Re: dthemi] #2939315
07/03/21 12:19 PM
07/03/21 12:19 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Ever try and charge the go lithium with the braille charger?
I know my braille goes to 18.2 full charge.
Re: Why are Vraille Lithium 16 volt Batteries... [Re: Sammy] #2939460
07/03/21 03:14 PM
07/03/21 03:14 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
18.2 is higher than GoLithium at 17.9
Re: Why are Vraille Lithium 16 volt Batteries... [Re: Al_Alguire] #2939483
07/03/21 04:00 PM
07/03/21 04:00 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I think that's the problem. Maybe unless you cut it off before 18.0
Re: Why are Vraille Lithium 16 volt Batteries... [Re: dthemi] #2939535
07/03/21 06:40 PM
07/03/21 06:40 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Me too, I always disconnect the Anderson plug while car is unattended.
I personally would be very cautious in not using the correct charger, for peace of mine, I would get what ever the manufacturer recommends. I am aware of 2 people who had battery fires, both occurred while battery was charging. Due to this, I never charge the batter, if I am not around to oversee.
Re: Why are Vraille Lithium 16 volt Batteries... [Re: mopar_mark] #2939559
07/03/21 07:52 PM
07/03/21 07:52 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Were both those battery fires with chargers not designated for those batteries?
Re: Why are Vraille Lithium 16 volt Batteries... [Re: MarkZ] #2939561
07/03/21 08:00 PM
07/03/21 08:00 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
I personally would be very cautious in not using the correct charger, for peace of mine, I would get what ever the manufacturer recommends. I am aware of 2 people who had battery fires, both occurred while battery was charging. Due to this, I never charge the batter, if I am not around bto oversee.
I don’t think so, probably not, but don’t know for sure,
