8 Speed AT in 1970 Charger #2936913
06/26/21 10:58 AM
06/26/21 10:58 AM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
I've done the Gen 3 conversions with the Tremec 6 speeds before, not hard at all. Now in my newest project, a Hellcat with a 8 speed trans. Who makes the trans mount conversion? Any other pitfalls I need to need about?
Re: 8 Speed AT in 1970 Charger [Re: DANA60] #2936993
06/26/21 01:57 PM
06/26/21 01:57 PM
GA
roadrunninMark Offline
GA
Holley has the trans mounts. Not sure on pitfalls other than tunnel clearance and the usual driveshaft conversion stuff
Re: 8 Speed AT in 1970 Charger [Re: DANA60] #2937160
06/27/21 01:34 AM
06/27/21 01:34 AM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Re: 8 Speed AT in 1970 Charger [Re: SRT6776] #2937501
06/27/21 11:02 PM
06/27/21 11:02 PM
IL
furious70 Offline
furious70  Offline
IL
boy that was a lot of work. Holley makes it sound like you just cut out the cross member and use their system, not all that tunnel work.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 8 Speed AT in 1970 Charger [Re: furious70] #2937536
06/28/21 04:49 AM
06/28/21 04:49 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
True, and I wouldn’t want to cut up a Mopar like that unless it’s a low-dollar car.
China is the enemy.
Re: 8 Speed AT in 1970 Charger [Re: 1972CudaV21] #2937820
06/28/21 08:50 PM
06/28/21 08:50 PM
IL
furious70 Offline
furious70  Offline
IL
I'd hate to be the guy that did all that work to that car and youtubed it if you really can just cut out the cross member and use the holley mount:
https://www.holley.com/products/eng...ine_and_transmission_mounts/parts/BHS539
they only have this for B bodies so far for some reason.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 8 Speed AT in 1970 Charger [Re: furious70] #2937856
06/28/21 11:24 PM
06/28/21 11:24 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
they only have this for B bodies 68-70 Chargers so far for some reason.
Re: 8 Speed AT in 1970 Charger [Re: A990] #2937889
06/29/21 07:11 AM
06/29/21 07:11 AM
Home
SRT6776 Offline
SRT6776  Offline
Home
I think there's a point when if you want all this stuff, you should just get a new challenger lol
Re: 8 Speed AT in 1970 Charger [Re: A990] #2938189
06/29/21 09:24 PM
06/29/21 09:24 PM
IL
furious70 Offline
furious70  Offline
IL
that's not what it says....
"1966-72 MOPAR B-BODY GEN III HEMI SWAP COMPONENTS"
This particular part says 68-70 b body, not just Charger.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 8 Speed AT in 1970 Charger [Re: furious70] #2938350
06/30/21 01:42 PM
06/30/21 01:42 PM
GA
GA
Isn't the b-body trans cross member fairly close to the e body?
My friend and I are each putting the 8 speed in our e body cars. I won't be ready probably until next year (for the body mods) but we are now working on getting the 8 speed to properly mount to the small block crank, figuring out flexplate spacing, tq mounting, etc..
Re: 8 Speed AT in 1970 Charger [Re: roadrunninMark] #2938559
06/30/21 11:02 PM
06/30/21 11:02 PM
IL
furious70 Offline
furious70  Offline
IL
you're using the TF8 with an LA engine?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 8 Speed AT in 1970 Charger [Re: furious70] #2938644
07/01/21 09:38 AM
07/01/21 09:38 AM
GA
GA
Furious, yes. Mine will behind a hopped up 318, his will be behind a hopped up 340.
Re: 8 Speed AT in 1970 Charger [Re: roadrunninMark] #2938696
07/01/21 11:57 AM
07/01/21 11:57 AM
K
Kiddart Offline
Kiddart  Offline
K
this is such a really cool idea, i hope this works out for you. What flex plate etc to do the swap are you using
Thank you
Kiddart
Re: 8 Speed AT in 1970 Charger [Re: Kiddart] #2938804
07/01/21 04:52 PM
07/01/21 04:52 PM
GA
GA
We are using the Quicktime -947 plate, it has to be drilled for the new TQ. We thought about using the stock plate but I talked to Ross at QuickTime and he said it is easier to drill the holes for the converter than it is to drill the holes for the crank. Plus the balance on the plate won't change when drilling the holes for the converter (symmetrical) as it could with the holes for the crank (non symmetrical). The tooth count is 1 less vs. the stock 8hp plate (130 vs. 131) it shouldn't be an issue.
Our next step is to get the spacing off the crank to the plate/converter correct for the input shaft and starter.
Didn't mean to hijack the thread from the original poster.....
Re: 8 Speed AT in 1970 Charger [Re: roadrunninMark] #2938842
07/01/21 08:24 PM
07/01/21 08:24 PM
Home
SRT6776 Offline
SRT6776  Offline
Home
FYI the next generation 8spd has an electric motor in it with something like 235hp and 335lbft
Re: 8 Speed AT in 1970 Charger [Re: SRT6776] #2938856
07/01/21 09:12 PM
07/01/21 09:12 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
work
Really?....... devil
Any more info?
Mo' Farts
Moderated by "tbagger".
Re: 8 Speed AT in 1970 Charger [Re: Grizzly] #2938899
07/02/21 12:46 AM
07/02/21 12:46 AM
Home
SRT6776 Offline
SRT6776  Offline
Home
"Previously confirmed with electrified assistance by the head of sales operations Matt McAlear, the all-new Charger and Challenger with the fancy 8HP box could arrive in mild-hybrid, hybrid, or plug-in flavors. The most powerful transmission is called 8HP80PH, and in P2 setup for plug-in applications, it cranks out up to 215 horsepower plus 332 pound-feet (450 Nm) of torque.
Combine these figures with the 6.2-liter supercharged V8 of the Super Stock that develops 807 horsepower and 707 pound-feet (959 Nm) on pump gas, and you’ll get 1,022 horsepower and 1,039 pound-feet (1,409 Nm) in total"
Dodge is showing off a new car on July 8th
Re: 8 Speed AT in 1970 Charger [Re: Grizzly] #2938968
07/02/21 10:20 AM
07/02/21 10:20 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Nice. The wife's 2020 Mercedes GLE 580 has a hybrid setup with an electric motor in between the engine and trans and it provides 30 hp and 120 lbs more torque to the biturbo 4.0.
Re: 8 Speed AT in 1970 Charger [Re: furious70] #2940794
07/07/21 11:57 AM
07/07/21 11:57 AM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
Holly's cross member will not work with the 90, just the 70.
Re: 8 Speed AT in 1970 Charger [Re: DANA60] #2940997
07/07/21 10:38 PM
07/07/21 10:38 PM
IL
furious70 Offline
furious70  Offline
IL
hmmm, I've not seen a difference in the cases documented - do you have any photos?
70 Sport Fury
68 Charger
69 Coronet
72 RR
