Re: Tunnel ram options above the carbs [Re: mopar dave] #2937106
06/26/21 08:53 PM
06/26/21 08:53 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Guys I know not all tracks enforce the rules totally but you should look at "Flash Shields" in the rule book. I've seen many sidelined because they didn't meet those requirements. It's not a new rule I know it goes back to the 50's.
Re: Tunnel ram options above the carbs [Re: mopar dave] #2937108
06/26/21 09:03 PM
06/26/21 09:03 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The round wire, in cross-section, is a surprisingly dirty (non aero) obstruction, and also disturbs air around it.
It's the reason screens do not protect jet engines against bird strikes: ruins the mileage.
Boffin Emeritus
Re: Tunnel ram options above the carbs [Re: polyspheric] #2937190
06/27/21 09:02 AM
06/27/21 09:02 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I wish I had more room under my hood scoop to run taller air cleaners or velocity stacks. I can only fit about 2" high filters on top of my carbs. I know it is not enough air flow and not high enough above the carbs. At one time I had a set of velocity stacks with the foam elements. Those seemed to work great. They were about 4" tall.
Re: Tunnel ram options above the carbs [Re: polyspheric] #2937198
06/27/21 09:21 AM
06/27/21 09:21 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
If a jet engine can pick a man up and suck him into the engine, i would think a jet engine would suck the screen in. I agree, anything over the opening is not the best. Open uncovered works best, but these screens work very well for street driving and not losing much.
Re: Tunnel ram options above the carbs [Re: mopar dave] #2937577
06/28/21 09:51 AM
06/28/21 09:51 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Scoop with a pair of K&N filters.No difference in AFR with or without filters. Without filters there is fuel being sucked out causing fuel vapor towards the windshield at speed.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Tunnel ram options above the carbs [Re: polyspheric] #2965203
09/18/21 09:56 AM
09/18/21 09:56 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I ran the car down the track and tested a few things last saturday. First off i found the filters with filter tops to be slower than the velocity stack with a screen lid. Ran a 6.60@105.89 8th mile. 6.544@106.30 with stack and a screen lid. 6.541@106.33 with stack and no lid. So, the screen is not really hurting enough for me to run without it.
Re: Tunnel ram options above the carbs [Re: mopar dave] #2965205
09/18/21 10:17 AM
09/18/21 10:17 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Home made Perspex scoop with RC2 4" filter. Unfortunately a hard landing after a big wheelstand broke it somewhat mad. The next one will have a 3mm Aluminium base plate grin. Only had one decent pass before breaking it (9.57 @ 141.??).
Re: Tunnel ram options above the carbs [Re: Tig] #2965207
09/18/21 10:36 AM
09/18/21 10:36 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Haven't tried one yet, but i'm thinking the oval filter may be the best way to filter on a tunnel ram.
Re: Tunnel ram options above the carbs [Re: mopar dave] #2965258
09/18/21 03:15 PM
09/18/21 03:15 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I run screens on my carbs for the street and put my Super Shaker over them. At cruise nights I cap them with the Moroso carb caps. Don't trust anyone dropping something down the carbs, just in case.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Tunnel ram options above the carbs [Re: Hot 340] #2965333
09/18/21 06:52 PM
09/18/21 06:52 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If a screen is large enough it's harmless, but per square inch it's a restriction compared to fully open.
The round wire used is a very dirty aerodynamic shape compared to a teardrop, ellipse, etc.
Boffin Emeritus
