Re: Late Model Dodge Truck AC expert needed [Re: Hemihead2] #2936576
06/24/21 11:17 PM
06/24/21 11:17 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Fwiw, agreed with everything IMGTX posted.
If you didn't flush the system and replace receiver/dryer I would do that when replacing the orifice or expansion valve
Re: Late Model Dodge Truck AC expert needed [Re: INTMD8] #2936610
06/25/21 07:19 AM
06/25/21 07:19 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I just did this repair on my son’s 05 1500 last year. Here’s the proper procedure. His compressor went out because he had a leak in one of his hoses. I replaced the compressor, the leaking hose, the accumulator/ dryer, the line with the orific tube in it( these don’t use an expansion valve) AND the condenser AND flushed the other parts or lines in the system. All these parts are not that expensive to replace and flushing is simple. If you did not do ALL of this, you probably have enough metal in the system to trash the compressor again. My advice, and your not going to like this, start over and replace everything and flush it . These new condenser have small passages and get stopped up very easily so they need to be replaced. A good working condenser is the key to a 134 system. His fan motor went out last month so we had to change it out as well. I suggest changing that out right now as well because you have to pull the condenser assembly out to change that. You might get lucky and nothing has gotten loose into the new compressor but don’t be surprised if it goes out soon. At least if you want to chance it, change the orific tube line and the condenser and flush the rest of the system. Good luck
Re: Late Model Dodge Truck AC expert needed [Re: INTMD8] #2936650
06/25/21 10:42 AM
06/25/21 10:42 AM
GMP440 Offline
GMP440  Offline
If you do end up flushing the system, since you have the system apart; the method I use is flush all the lines with lacquer thinner, then flush again with acetone. The acetone will dry the system out. I do this with all my auto a/c systems.
Re: Late Model Dodge Truck AC expert needed [Re: Hemihead2] #2936758
06/25/21 06:00 PM
06/25/21 06:00 PM
Pa
Hemihead2 Offline OP
Pa
That will do it every time…completely blocked the whole way into the orifice….I got it all back together and blowing at 42.8* now…Thanks for your help everyone![img]http://[/img]
Re: Late Model Dodge Truck AC expert needed [Re: Hemihead2] #2936776
06/25/21 07:07 PM
06/25/21 07:07 PM
GMP440 Offline
GMP440  Offline
Did you flush all the black goo out?
Re: Late Model Dodge Truck AC expert needed [Re: Hemihead2] #2936780
06/25/21 07:17 PM
06/25/21 07:17 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Did you flush the system out REALLY WELL . if not you be doing it again very soon
