rocker panel pinchweld blackout. brushed or sprayed? #2935801
06/22/21 08:34 PM
06/22/21 08:34 PM
Canada
demon Offline OP
demon  Offline OP
Canada
On original 70-71 B and E bodies, was the rocker pinchweld blackout done with a brush, or was it sprayed? If sprayed, was it done with a template or mask of some kind? Anyone have photos or documentation? Thank you
Re: rocker panel pinchweld blackout. brushed or sprayed? [Re: demon] #2935828
06/22/21 09:40 PM
06/22/21 09:40 PM
MD
floyd Offline
floyd  Offline
MD
I studied some original T/As when I was doing my car and most of the ones I saw appeared to have been brushed.
Re: rocker panel pinchweld blackout. brushed or sprayed? [Re: demon] #2935843
06/22/21 10:36 PM
06/22/21 10:36 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Combination of all of the above, masked, sprayed, brushed, you need to narrow down the specific model and year to achieve the answer you seek
Re: rocker panel pinchweld blackout. brushed or sprayed? [Re: DAYCLONA] #2935853
06/22/21 11:08 PM
06/22/21 11:08 PM
Canada
demon Offline OP
demon  Offline OP
Canada
OK, working on a 71 Charger R/T. It had one repaint, so the original black out is only partially visible. I don't see any brush marks. Also wondering if the little tabs on the fender lip where the brace attaches to the firewall were blacked out as well.
Re: rocker panel pinchweld blackout. brushed or sprayed? [Re: demon] #2935878
06/23/21 02:30 AM
06/23/21 02:30 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Has anyone seen both on same car?
Re: rocker panel pinchweld blackout. brushed or sprayed? [Re: autoxcuda] #2935908
06/23/21 07:38 AM
06/23/21 07:38 AM
MA
steve70 Offline
steve70  Offline
MA
original T/A
1970 Challenger T/A 4 speed
Re: rocker panel pinchweld blackout. brushed or sprayed? [Re: steve70] #2935909
06/23/21 07:40 AM
06/23/21 07:40 AM
MA
steve70 Offline
steve70  Offline
MA
71 SuperBee
Re: rocker panel pinchweld blackout. brushed or sprayed? [Re: steve70] #2935923
06/23/21 09:11 AM
06/23/21 09:11 AM
Canada
demon Offline OP
demon  Offline OP
Canada
Thank you very much. Just what I was looking for. Those all appear to be sprayed. The rockers look like they used a low pressure spray, at a close distance, which would make sense to avoid getting it on the outer surface of the car.
Re: rocker panel pinchweld blackout. brushed or sprayed? [Re: demon] #2935946
06/23/21 10:17 AM
06/23/21 10:17 AM
MA
steve70 Offline
steve70  Offline
MA
Here are the specs. it states spray, brush or optional tape?
Re: rocker panel pinchweld blackout. brushed or sprayed? [Re: steve70] #2938065
06/29/21 04:04 PM
06/29/21 04:04 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Two 71 bee’s and both definitely brushed
