Cost to switch from a Hemi to Predator?
#2935323
06/21/21 03:14 PM
06/21/21 03:14 PM
Posts: 12,395 Taxes & Virus's R-US, NY
Dragula
Does anyone make headers for the Predator heads? I am guessing that's a big no. It would be nice if my Hemi headers fit them. Anyone ever switch a Hemi block over to Predator heads?
Re: Cost to switch from a Hemi to Predator?
[Re: Dragula]
#2935439
06/21/21 10:18 PM
06/21/21 10:18 PM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
[Re: FastmOp]
#2935614
06/22/21 12:23 PM
06/22/21 12:23 PM
Posts: 3,023 NY
B1duster
NY
[Re: B1duster]
#2935651
06/22/21 02:26 PM
06/22/21 02:26 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Nothing will switch over but the block, crank, the camshaft although it uses the same lobe pattern I doubt highly it would be predator friendly. You can get Predators in Wedge and Hemi patterns, and I guess the rods if you so chose too. Everything else will be Predator specific. Want a ballpark number $10-12K if you wanna do it right
[Re: Al_Alguire]
#2935660
06/22/21 02:55 PM
06/22/21 02:55 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
You'll be building headers too. I don't think there's an off the shelf header made for those heads.
[Re: Al_Alguire]
#2935663
06/22/21 03:11 PM
06/22/21 03:11 PM
Posts: 4,101 Yes
sixpakdodge
Yes
Nothing will switch over but the block, crank, the camshaft although it uses the same lobe pattern I doubt highly it would be predator friendly. You can get Predators in Wedge and Hemi patterns, and I guess the rods if you so chose too. Everything else will be Predator specific. Want a ballpark number $10-12K if you wanna do it right I would think it would be more money? Indy wants $11k for just the Predator head kit. Probably better off selling the Hemi and starting from scratch.
[Re: sixpakdodge]
#2935700
06/22/21 04:11 PM
06/22/21 04:11 PM
Al_Alguire
Las Vegas
Nothing will switch over but the block, crank, the camshaft although it uses the same lobe pattern I doubt highly it would be predator friendly. You can get Predators in Wedge and Hemi patterns, and I guess the rods if you so chose too. Everything else will be Predator specific. Want a ballpark number $10-12K if you wanna do it right I would think it would be more money? Indy wants $11k for just the Predator head kit. Probably better off selling the Hemi and starting from scratch. Or DONT buy the kit from Indy. Buy bare heads and have a GOOD cylinder head guy prep them for you, rocker gear if you like but price is the same as buying direct from T&D. Then its an intake and valve covers preferably not the heavy cast stuff. But what do I know
[Re: Dragula]
#2935806
06/22/21 08:51 PM
06/22/21 08:51 PM
Posts: 16,928 NC
440Jim
NC
Anyone ever switch a Hemi block over to Predator heads? What CID and how much power is your Hemi combo making now? What power level is your Predator goal? I imagine a full out Predator engine can make more power, but if you are going to reuse a 572 CID block, crank, and rods; I would think good Hemi heads can make lots of power.
