Re: Unopened Engine Oil Shelf Life?
[Re: B1MAXX]
#2935530
06/22/21 08:00 AM
06/22/21 08:00 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
if it's been stored properly oil will still be good for a LOONNNGGGG time.
20 years ago i bought a pallet of castrol gtx 20w50 oil in quart bottles dirt cheap. i stored the oil in my basement.
i used the last quart 4 or 5 years ago. never had any problems with it.
perception is 90% of reality
[Re: cudaman1969]
#2935568
06/22/21 09:58 AM
06/22/21 09:58 AM
Posts: 6,291 nowhere
Sniper
nowhere
I have some really old engine oil my neighbor gave me. I use it for bar and chain oil on my chain saw. I don't use it in engines. Why? Because I am old and I know from experience old stuff doesn't perform the same as it did when it was new and that is just as scientific as the clowns on bobistheoilguy thinking since it "looks" ok it must be ok. If the manufacturer gave it a shelf life that weighs more on my decision making process than a bunch of internet "experts" I don't know and who won't be paying the freight when something bad happens. Besides, are you going to save $5 at the possible expense of thousands if something bad does happen? Penny wise, pound foolish comes to mind.
[Re: Sniper]
#2935616
06/22/21 12:27 PM
06/22/21 12:27 PM
Posts: 12,213 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Because I am old and I know from experience old stuff doesn't perform the same as it did when it was new and that is just as scientific as the clowns on bobistheoilguy thinking since it "looks" ok it must be ok. If the manufacturer gave it a shelf life that weighs more on my decision making process than a bunch of internet "experts" I don't know and who won't be paying the freight when something bad happens. 53 responses in that thread and those particular ones are your take-away. Even though they do not accurately reflect the consensus. There actually is some good information in there for those that don't go in with a negative attitude. But there are always those that have an agenda and look for every little piece that they can dredge up to support it. And as an FYI; I don't use any oil over 2 years old myself. I don't know what the time limit is on any particular brand of oil, but 2 years is well under any brand that has a 'use by' recommendation.
Master, again and still
[Re: DaveRS23]
#2935632
06/22/21 01:26 PM
06/22/21 01:26 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
53 responses in that thread and those particular ones are your take-away. Even though they do not accurately reflect the consensus. One must recognize the value of anecdotal experience i.e. doing it wrong and getting away with it versus doing it right.
[Re: John_Kunkel]
#2935634
06/22/21 01:34 PM
06/22/21 01:34 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
And one must realize the value of collective anecdotal experiences. All of us, at least to some extent, rely on them everyday.
[Re: Cab_Burge]
#2935833
06/22/21 09:57 PM
06/22/21 09:57 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Well this went down hill in a hurry.
[Re: hemirdrnnr]
#2936014
06/23/21 01:26 PM
06/23/21 01:26 PM
John_Kunkel
Rio Linda, CA
If you do use it remember to shake it up before you use it. The thought is that chemical additives that have dropped out of suspension due to moisture absorption with age will dissolve and return to suspension...not so.
[Re: vinnyd76]
#2936052
06/23/21 03:22 PM
06/23/21 03:22 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
Just because I've never had a problem doing that, doesn't mean someone else won't. So if a person feels safer not doing that, then don't do that........
In the mid-2000s I finally ran out of the large quantity of Valvoline racing oil bought for next to nothing when AutoWorks closed down in the '90s. I used it in all the old carbureted Mopar engines.
Recently finished a stash of some SJ Mobil 1 10w30, in the 440 that is in my C body. SJ hasn't been available since (I believe) around 2001. I guess it could explode tomorrow, but I'd expect a 1973 cast piston to fail long before any kind of an oil problem.
In both cases the product was stored in a fairly controlled climate until I used it, and FWIW did not have visible additive fallout. If there were any visible additive fallout, I either wouldn't have used it at all or would have gone in my tractor.
Have inventory of discontinued Rotella 10w30 and Delo 400 SAE30 dual rated oils among others, it will take time to use it up but it's nice to have stock on hand to use when convenient.
Should I ever suspect any oil of being no longer useful, contaminated or out of spec due to age, if I had a large quantity I'd send in a sample for analysis before running it. As analysis typically does not support the notion of an expiration date, it would be interesting to see the results, and it's usually reasonable from a time and cost perspective.
Never forget-Oil is like Religion, and (to many), the more you spend...the cooler you are.
Rich H.
Esse Quam Videri
[Re: vinnyd76]
#2936085
06/23/21 04:42 PM
06/23/21 04:42 PM
Posts: 4,848 Memphis
HemiRick
Memphis
the oil was in ground for millions of years before it was refined and put that bottle, I'm sure its fine.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2936087
06/23/21 04:45 PM
06/23/21 04:45 PM
Sniper
nowhere
the oil was in ground for millions of years before it was refined and put that bottle, I'm sure its fine. Try putting plain old crude in your engine and see how long that runs. The oil in the ground is pretty much completely different than the refined stuff with all the additives that you put in your engine. But go ahead with that thinking.
