Which Melling pickup tube with 6qt Hemi pan?
#2935162
06/21/21 12:14 AM
06/21/21 12:14 AM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
I bought a 440Source six quart “Hemi” pan for my 440. Which Melling pickup tube do I use, the 63S3 or 63S4? I’ve read through several posts and I’m seeing conflicting answers. I believe the S4 is for 402 style pans, and the S3 is for the 73+ B-body pans. My block appears to still be tapped for a 3/8 tube. Thanks
Re: Which Melling pickup tube with 6qt Hemi pan?
[Re: Montclaire]
#2935284
06/21/21 01:03 PM
06/21/21 01:03 PM
Montclaire
Scranton, PA
Anybody? I’d like to order one before COB. Thanks
[EDIT] 440Source was no help, they only wanted to sell me their pickup tube (which several posters have complained about). I guess the purchase of the pan, a crank pulley and several other parts in the past wasn't enough $$ for a little free tech advice. Lesson learned.
[Re: Cab_Burge]
#2935408
06/21/21 08:04 PM
06/21/21 08:04 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I like the straight pick-up that I used on my 493 with a street HEMI pan. I got mine from Summit but Mancini has them too Item #: MOPP4529565 Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Cab_Burge]
#2935476
06/22/21 12:23 AM
06/22/21 12:23 AM
Montclaire
Scranton, PA
63-S4 is the 3/8 pickup I use now, it has a dogleg bend in it and is real close to the bottom of the of the same pan sold by Summit Melling use to sell another pickup 3/8 inch that was straight with a different part number that was easier to install into stroker motors but I can't remember that part number now, CRS Thanks, Cab - you mentioned the S4 in an old post but I was having a hard time finding any others to back it up. I’m assuming anyone who recommended the S3 was using a different pan or didn’t mind a little modification to the tube (or just confused the part numbers).
[Re: fourgearsavoy]
#2935480
06/22/21 12:29 AM
06/22/21 12:29 AM
Montclaire
Scranton, PA
I like the straight pick-up that I used on my 493 with a street HEMI pan. I got mine from Summit but Mancini has them too Item #: MOPP4529565 Gus I would have bought the mopar tube but it’s on back order through the bigger vendors. Should I use a little rector-seal on the threads?
[Re: Montclaire]
#2935504
06/22/21 01:53 AM
06/22/21 01:53 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
