'68 3-speed wiper motor will it work in a '69 GTX? #2933024
06/14/21 12:16 AM
06/14/21 12:16 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
I've been looking for a 3-speed wiper motor for my '69 GTX so I could put an original Air Grabber system on it. Today I needed to move (re; clean out) some parts from the garage to a shed/12'x24' building when I came across a '68 B-body 3-speed wiper motor part number 2889982 with a 3607 date code that I forgot I had. Will this work with my '69 GTX or do I need to make some mods or is there no way it will work and I'm SOL? Of course it will need cleaned up rolleyes and at some point professionally restored. At this point I'm not really concerned with the date code just want to get the AG on the car then go from there. Thanks in advance.
Yeah it's a bute Clark and at this point I'm not sure if it even works....but at least it won't hit the Air Grabber wink If it doesn't work I'll just Rain-X the windshield and drive home fast drive laugh2
Mike
Re: '68 3-speed wiper motor will it work in a '69 GTX? [Re: A12] #2933066
06/14/21 07:39 AM
06/14/21 07:39 AM
VA
dragon slayer Offline
VA
The motor will work, you might need a different lever/cam to operate the 69 but I am not positive on that. The parts book would help you determine lever you need.
Re: '68 3-speed wiper motor will it work in a '69 GTX? [Re: dragon slayer] #2933133
06/14/21 11:21 AM
06/14/21 11:21 AM
N
NITROUSN Offline
NITROUSN  Offline
N
See what number is on the link. My 69 has this 3 speed 2822273
Re: '68 3-speed wiper motor will it work in a '69 GTX? [Re: NITROUSN] #2933194
06/14/21 01:10 PM
06/14/21 01:10 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
If the P/N on the crank is 2580934 and says V-speed it would just bolt in. You would need the 3sp switch also
I have restored motors with the correct P/N
ns1aar.com
NS1AAR
Re: '68 3-speed wiper motor will it work in a '69 GTX? [Re: ns1aar] #2933232
06/14/21 02:50 PM
06/14/21 02:50 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Im afraid i cant answer if it will work or not....odds are yes.
BUT....
imo. Put the right one on the car . Do it once do it right and be done
OE is probably 2983116 i think
Re: '68 3-speed wiper motor will it work in a '69 GTX? [Re: gtx6970] #2933276
06/14/21 05:48 PM
06/14/21 05:48 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Part numbers for 69 A/B body would be
2983033 for cars built before Nov 68
2983116 for cars built after Nov 68
They do comingle
They are electrically and mechanically the same
NS1AAR
Re: '68 3-speed wiper motor will it work in a '69 GTX? [Re: ns1aar] #2934493
06/18/21 11:09 AM
06/18/21 11:09 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Sent a pm don't know if you received it ?
Thanks for the info. up
They do comingle
Re: '68 3-speed wiper motor will it work in a '69 GTX? [Re: gtx6970] #2934495
06/18/21 11:12 AM
06/18/21 11:12 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
BUT....
Bill where's the best place to find one?
Would this wiper motor I have (posted) have a core or any value towards a '69 motor??
Thanks,
Mike
Re: '68 3-speed wiper motor will it work in a '69 GTX? [Re: A12] #2934537
06/18/21 12:31 PM
06/18/21 12:31 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
BUT....
Thanks,
Mike
Im sure it has some core value, as to how much depends on who is interested in it
NS1AAR above you posted earlier he has the right one. And there are others out there restoring them or scour swap meets and or ebay
Re: '68 3-speed wiper motor will it work in a '69 GTX? [Re: A12] #2934735
06/18/21 11:37 PM
06/18/21 11:37 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
They do comingle
PM sent
NS1AAR
Re: '68 3-speed wiper motor will it work in a '69 GTX? [Re: gtx6970] #2934736
06/18/21 11:38 PM
06/18/21 11:38 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Yes I have them
NS1AAR
