Re: Engine Masters: 6pack vs HEMI
[Re: mgoblue9798]
#2934709
06/18/21 10:20 PM
06/18/21 10:20 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Actually a 426 max wedge v/s hemi would be an interesting shootout. I'd like to see a small block vs gen 3 hemi shootout - maybe what can be built for 5k. Small block stroker vs 6.4 would be interesting as well. 5 K don't buy much these days. I just finished a 408 stroker and with machining , I am well over that. I also have a 405 inch R-3 / W-9 and I have well over that in the heads.
[Re: hudsonhornet7x]
#2934720
06/18/21 10:39 PM
06/18/21 10:39 PM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
but who builds stock displacement engines anymore? I just did ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: INTMD8]
#2934724
06/18/21 10:50 PM
06/18/21 10:50 PM
Posts: 1,545 USA
hudsonhornet7x
USA
but who builds stock displacement engines anymore? I just did Fair enough lol. What did you build?
[Re: INTMD8]
#2934726
06/18/21 10:53 PM
06/18/21 10:53 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
The 1971 440 Six Pack is going back in his 1971 Charger R/T , his first car
The Mopar Performance 426 Hemi is going in a AMC Gremlin on a future episode of roadkill
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: tubtar]
#2934737
06/18/21 11:44 PM
06/18/21 11:44 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
Actually a 426 max wedge v/s hemi would be an interesting shootout. I'd like to see a small block vs gen 3 hemi shootout - maybe what can be built for 5k. Small block stroker vs 6.4 would be interesting as well. 5 K don't buy much these days. I just finished a 408 stroker and with machining , I am well over that. I also have a 405 inch R-3 / W-9 and I have well over that in the heads. I was thinking about a 5.9 with a set of pistons, cam, and heads, vs 5.7 with something similar as far as cam and compression goes. Regular guy street stuff, not racing engines.
[Re: metallicareload]
#2934746
06/19/21 01:13 AM
06/19/21 01:13 AM
Posts: 5,169 CT
GTX MATT
CT
I did not know that Stage V made a dual plane? Somehow I suspect that a stock intake would have made more torque. https://www.hotrod.com/articles/mopp-0310-hemi-426-crate-engine-dyno-test/This is an article from Dulcich on Westechs dyno from 20 years ago. The otherwise stock 465 HP crate motor he used made WAY more low end torque with more cam with the crate motor intake manifold. How much do you want to bet its actually the same crate engine?
[Re: polyspheric]
#2934788
06/19/21 10:04 AM
06/19/21 10:04 AM
Posts: 4,796 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Wedge motor was a successful transition of a passenger car engine design adapted to racing. Hemi was a successful transition of a race car engine design adapted to passenger car use. Many OEM heads can support 500hp. The iron OEM hemi head shines when tasked to make far FAR beyond that level. Hemi is cool and legendary but If I could afford one run Id let those big ole heads shine with big cubes and high RPM.
Keep old mopars alive.
[Re: krautrock]
#2934829
06/19/21 12:26 PM
06/19/21 12:26 PM
Posts: 4,715 Wichita
GY3
Wichita
what were the cams in the motors for the dyno test comparison? Hydraulic rollers. Duration was 236° @ .050 intake, 241 @ .050 exhaust. Lift was .549 intake, .541 exhaust with 108° lobe separation.
[Re: cudaman1969]
#2934831
06/19/21 12:57 PM
06/19/21 12:57 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
You can build a 440 to have more power than a Hemi, then try to sell either. Buyers are standing in line to pay big bucks for the Hemi and you have to give away the wedge, facts of life folks. One other thing, I haven’t seen any 68 440 Darts or Cudas in Super Stock trim run as fast as the Hemi ones yet. let se, a single four barrel with stock smog heads versus two four barrels on a race motor, I wonder why the hemi does better in those cars ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) for those that don't know about the stock hemiroid valve train take a real hard look at them, they SUCK ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: Cab_Burge]
#2934872
06/19/21 02:50 PM
06/19/21 02:50 PM
Posts: 8,373 fredericksburg,va
cudaman1969
fredericksburg,va
You can build a 440 to have more power than a Hemi, then try to sell either. Buyers are standing in line to pay big bucks for the Hemi and you have to give away the wedge, facts of life folks. One other thing, I haven’t seen any 68 440 Darts or Cudas in Super Stock trim run as fast as the Hemi ones yet. let se, a single four barrel with stock smog heads versus two four barrels on a race motor, I wonder why the hemi does better in those cars ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) for those that don't know about the stock hemiroid valve train take a real hard look at them, they SUCK Exactly what I mean, no smog motor headed 440 even with the 6 Pac will run like a Hemi unless you restrict the Hemi (with hdydrolic cam) to run in the same rpm range. Build the 440 just like the race Hemi using the 906 head with a sheet metal intake (same mods as the S/S) no way you’re getting 8-900 HP out of that 440. First off those 906s will choke off at 6800 or less. Below the head, the 440 and 426 are the same, the head and above separates the men from the boys. Once the aftermarket wedge heads start flowing in the Hemi range then and only then will the engines match up.
[Re: Uberpube]
#2934878
06/19/21 03:07 PM
06/19/21 03:07 PM
mgoblue9798
Atlanta, GA
Anyone watch it? Interesting results. Has me wondering if the cams should have shared the same lift but otherwise been customized to suite each engine best. How about a link to it so we can watch it They are having a Father's Day sale, $36 a year. Well worth it. https://www.motortrend.com/news/motortrend-app-fathers-day-gifts/ Deal only available in the US. Bummer. If you get a VPN you can be a US customer as well.
[Re: GY3]
#2934891
06/19/21 04:02 PM
06/19/21 04:02 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I just finished it and it was very interesting!
It's the same thing that had been said for years.
You have to spin the HEMI hard to get it to run. Not so much with the 440 as it makes tons more low end torque.
Here is a screenshot of the runs overlaid. Red is 440, black is Hemi. Sorry I don't know any other way to say this but If you increase the TQ per cube on the 426 to the same TQ per cube X 440 it is only down about 20lbs to the 440. The HP would also go up a little from the bigger bore unshrouding the valves more and the CID increase. Another way to look at it is you can always multiply TQ with gears but you can not multiply HP, what the engine makes is what it makes. In the same car with either cubic inch equal or gearing adjusted for the lower CID the hemi will win.
[Re: 2boltmain]
#2934895
06/19/21 04:22 PM
06/19/21 04:22 PM
Posts: 4,213 New York
polyspheric
New York
In Chrysler, the hemi is the older engine by 7 years (1951 vs 1958), and the B/RB wedge is not a descendant of any hemi.. In general, the wedge (pushrods and rocker arms, closed chamber with quench, parallel valves tilted at an angle to the bore axis) only came into general use in 1949 (Cadillac and Olds, and still used today in LSX), but the Harley-Davidson hemi engines date to 1926 and every English bike mfg. had a hemi engine before WW2.
Boffin Emeritus
[Re: Cab_Burge]
#2934945
06/19/21 10:42 PM
06/19/21 10:42 PM
moparpollack
Lil Herman
Lil Herman
85086
If you insure through Hagerty they give you motor trend for free.
MT jumped the shark years ago haven't watched any new content in 3 years.
