Re: SB Trick Flow 190 heads- FAIL
[Re: Publicbottle]
#2931289
06/08/21 02:03 PM
06/08/21 02:03 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Looks more like a casting flaw than an actual crack.
[Re: justinp61]
#2931423
06/08/21 08:00 PM
06/08/21 08:00 PM
fast68plymouth
So. Burlington, Vt.
I wasn’t going to post anything, but eh...... I’ll throw in my .02.....
“If it were me”, and replacement heads were a long wait away......... and I was ready to use the heads pretty soon...... I’d contact TF, send them a few pics of the casting flaw and get their take on it.
I can’t tell from the pic exactly where on the head that coolant hole is, but it may not be in a critical/problem area.
Seems like I read thru the paperwork that comes with the heads that the castings have a pretty good warranty on them.
If I felt the flaw was in a non-critical area(need more pics), and they’ll stand behind the integrity of the head.......... and I’m ready to use it now, and a replacement isn’t coming soon........ if those conditions all exist........ I’d use it.
As for “quality” parts that arrive in other than perfect condition, there’s a thread running here now about a new Callie’s RB block that arrived missing some head bolt holes....... but did have a few other holes it wasn’t supposed to.
That’s a part that’s over 2x the cost of a pair of TF heads.
[Re: fast68plymouth]
#2931481
06/08/21 10:28 PM
06/08/21 10:28 PM
Posts: 6,149 Melbourne , Australia
LA360
That is unfortunate that it's gotten through their quality control, It happens from time to time. Quite frankly, depending on where it is exactly, you probably could have fitted it and never had an issue. At least you didn't have the engine together and discover a fatal flaw. A friend discovered the AFR heads he had on a customers BBC, the rocker stand pads were 0.060" different to one another. He was doing final assembly at the time.
Hopefully they get another head to you in a timely fashion.
The Trickflow stuff is pretty good generally, I've seen a few BBM and BBF heads/intakes, they've been finished nicely.
Alan Jones
#2934490
06/18/21 11:02 AM
06/18/21 11:02 AM
Posts: 885 alberta
Publicbottle
alberta
That’s a part that’s over 2x the cost of a pair of TF heads. I somewhat agree with you about running them "as is" based off what TF would have to say about the location and other details. I am waiting for other parts to complete the engine anyway, so that was my primary factor in sending the head back. I also sent back the harland sharp rockers as one of the rocker arms has tooling marks or some other marring..under the anodizing...could be nothing, but why risk it at this point ...I'm not a real big risk taker plus I have some time on my side... Summit stated end of July for the new parts to ship out...
[Re: Publicbottle]
#2934505
06/18/21 11:32 AM
06/18/21 11:32 AM
Posts: 43,293 Bend,OR USA
Cab_Burge
Way better to be safe than sorry on the crack I would have used those rocker arms as is in a New York second in a heartbeat
[Re: Cab_Burge]
#2934586
06/18/21 02:24 PM
06/18/21 02:24 PM
fast68plymouth
So. Burlington, Vt.
Way better to be safe than sorry on the crack I would have used those rocker arms as is in a New York second in a heartbeat I would have used the head too.
#2934607
06/18/21 03:44 PM
06/18/21 03:44 PM
Posts: 1,051 The Great White North
RAMM
Way better to be safe than sorry on the crack I would have used those rocker arms as is in a New York second in a heartbeat I would have used the head too. Me too after a pressure test. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
