68 and earlier self adjusting drums #2933831
06/16/21 07:33 AM
06/16/21 07:33 AM
Indiana
68_661charger Offline OP
Indiana
With the rear 10 inch drum brakes adjuster lever on top of the star wheel, as it's supposed to be on 68s, do the adjusters work while braking forward or backwards? 70s and later drum brakes have the adjuster lever engaging the bottom of the star wheel and I can imagine the process working while braking in reverse. Is this why it was changed because the early cars adjusted going forwards? Thanks in advance all.
Re: 68 and earlier self adjusting drums [Re: 68_661charger] #2933862
06/16/21 09:24 AM
06/16/21 09:24 AM
Ohio
carteravs Offline
carteravs  Offline
Ohio
According to a service bulletin, the earlier brakes were capable of over tightening, hence the change.
Re: 68 and earlier self adjusting drums [Re: 68_661charger] #2933887
06/16/21 10:23 AM
06/16/21 10:23 AM
GMP440 Offline
GMP440  Offline
Yes, the adjusters work while you hit the brakes in reverse. The L-shaped lever has a part of the arm that lines up at the bottom part of the star wheel on the adjuster assembly.
The braking motion in reverse causes the arm to push on the star wheel to rotate it , tightening the brakes a little at a time.
Re: 68 and earlier self adjusting drums [Re: GMP440] #2933914
06/16/21 12:08 PM
06/16/21 12:08 PM
Indiana
Indiana
Ok so both early and late self adjusters tighten in reverse. Thanks.
Re: 68 and earlier self adjusting drums [Re: 68_661charger] #2933928
06/16/21 01:10 PM
06/16/21 01:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If they adjusted going forward you'd have the wheels locked up very quickly.
Re: 68 and earlier self adjusting drums [Re: stumpy] #2933965
06/16/21 03:08 PM
06/16/21 03:08 PM
Indiana
Indiana
Agreed the motion of backing up and the lever pushing down didn't feel as logical as backing up and the lever pulling up at the star.
Re: 68 and earlier self adjusting drums [Re: 68_661charger] #2934047
06/16/21 08:25 PM
06/16/21 08:25 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Just for the record, the brakes need to be adjusted pretty close before any of the self adjusters will work very well.
Re: 68 and earlier self adjusting drums [Re: poorboy] #2934272
06/17/21 02:29 PM
06/17/21 02:29 PM
moparx Offline
moparx  Offline
also, the adjusters themselves need to be free, and the backing plates free of wear "divots" on the pads the shoes rest on.
beer
